I am new here, and recently got back into model RR and loving it!
I recently installed the MRC sound decoder into the Kato EMD E5 silver bullet. Everything I had read stated that this fits. The decoder indeed does fit onto the frame (per the instructions of trimming plastic tabs). I started it and programmed the long address. It works great and sounds OK (seems a little soft, wish it were louder). I did have to trim off the back LED as the Silver bullet does not require it.
Here the issue, it seems the shell will not go all the way down??? I am not sure if it is the speaker or the short LED on the front. It looks like it should fit, but I think the LED is holding it up. Looking at the original light board, the LED seems to extend out farther and angles down. The 1645 decoder LED is short and not really able to bend down??? Any ideas?
Well, you answered your own question; the origional Led is extended for a reason. Match up the sound decoder with the origional light board and you will be fine. Right now, your options are either to replace the led with one that will replicate the origional light board led length or clip off the head of the led on the sound card and extend it by attaching another led to the leads to match the length. Either way you are soldering. David B
