I have Intermountain, Proto and Genesis F units, and Highliner kits I built myself. No question the Athearn/Highliner is the very best F unit shell. But overall, the Intermountain and Proto F’s are both a very close second.
And all three drives are very nice, while all three have their minor flaws…
Disclamer - I got bored with OCD rivet counting years ago…
It’s interesting that the tall fans would sometimes be replaced with lower ones.
It’s especially interesting to me that GN was sort of random about that on their passenger F’s:
In the photo, the first two fans on the lead unit are the low style, while #3 is still the high. One can also see that there is a raised fan grill on the top of the winterization hatch–also unusual.
Ed, think of it this way, EMD improved the design of the fans, your old style fan wears out, why not install the better style? At some point I suspect the parts to repair/replace the old style became obsolete.
I doubt there was any big change to the car body regarding how the two fan styles are mounted, considering it was “running change” during F3 production.
I have a bunch of F3s of different brands. Intermountain is one LLProto 1000, and Stewart. Intermountain is overall the best with Stewart close behind The proto 1000 comes in last mainly they come with only one headlight where as the others have 2 Inter mountain and proto have good fans and to me they look close enough Stewart has low profile which are not correct. None of these are real important but what bugs me more than that is where they paint the things with the wrong colors.
Or accept a UP F3 with a lower number–with the high fans. UP had both high and low fans on their F3’s. Depending on the number. And, perhaps, the date–since the fans can be changed out. I just saw a shot of UP 1421 with a high fan housing for the #1 position, and low for #2 and #3. And witherization on #4.
If off-the-shelf suits ya, as it frequently does me, fine. If you (or I) want something different and want to build it, also fine.
Ed, theses days, close enough is always good enough for me. Depite my knowledge of the prototype, I have long been in the camp of “overall impression” rather than “exactly correct”.
Heck, 95% of my passenger car fleet, B&O, C&O, WM and freelance ATLANTIC CENTRAL, are generic 72’ cars…with lots of detail and close coupled with working diaphragms.
That feature of realism is more noticable, to more people, than exact window arrangements or even car length.
Some later F3s had automatic transition, the F7s with the 567BC engines didn’t start production until September 1953, and the D47 traction motor was not used by EMD until mid 1959. Also a few F7s were built with 567C engines to try them out.
The low profile fans on the Stewart F3 are NOT wrong, depending on what road name you have. The Reading bought very late F3s which had the low fans of the F7.
They are wrong for the CGW. Stewart released F3s in CGW paint. For the ones they released the low profile fans are incorrect. Overall tho I like the Stewart locos. Good runners nice looking.
The ones that have chicken wire grills. The ones Stewart did had chicken wire grills and low fans which are not correct. The one you showed was what a lot of people called an f5. Those are externally almost identical to an f7. If there are differences externally I am not aware of it.
The BAR had F3s with Chicken wire with both low and high fans. The first few came with high fans and some were modified with low fans through the shops. One number 42 kept the high fans through the 1970s.
Early F3s had three windows like the prior F2 had. Later they switched to two like the later F7 and F9. As has been mentioned, things like fan placement or height, screening/louvers etc. changed as EMD made improvements. When EMD updated something they normally didn’t keep producing the earlier version, so a railroad ordering F3s might in one year might get somewhat different looking engines than if they got another order of F3s the next years. It’s like buying a 1957 Chevy BelAir and later buying a 1960 BelAir. Same model, but didn’t look the same.
The carbodies of F2 through F9 units were essentially the same. Number boards were small on F2’s and early F3’s, but were replaced with large boxy ones on later F3’s and subsequent deliveries. The F2’s and early F3’s had high fans, but late F3’s and subsequent deliveries had low fans. Later, these were sometimes swapped in shopping. F2’s and early F3’s had flat panels with openings on the upper sides, often covered with chicken wire screening. Late F3’s (sometimes referred to as F5’s) and later deliveries had grilles over the upper side panels. That’s an extremely oversimplified rundown. Don’t forget to check the pilot. Many early F’s were delivered with streamlined pilots instead of the common Bulldog pilot.
B&O’s passenger F3 AB sets were delivered with high fans and streamlined pilots. Their freight F3’s were delivered in AA sets with low fans and Bulldog pilots. When Stewart released the B&O F3 with high fans many years ago, I bought a few of them and replaced the high fans with low ones that I ordered from Stewart as replacement parts. It was a simple pop-in replacement.
This discussion of F-3 and F-7s reminds me of a photograph of Santa Fe’s 263C I shot in Oklahoma City in 1974. It had the horizontal louvers of an F-7 between the portholes but the chicken wired carbody openings similar to an F-3 above them. The unit was in fact an F-7 built without the perforated grilles of most F-7s for what reason is unknown. It was part of a series of eight A-B-B-A sets numbered 260L,A,B,C-267L,A,B,C, which were built in the middle of the 202L,A,B,C,-280L,A,B,C group of F-7s. There have been EMD covered wagons that lost their grilles during their lives but these ATSF units were delivered with out them.
