EMD SD90MAC;s
  1. Well, the EMD Series 265H engine, was developed, essentially in collaboration with Siemens, of Germany…they laughed the long standing two cycle EMD engineers out of the room, for being “sloppy.”
As for a smaller 4-cycle, I don’t remember any info suggesting that.
The idea behind the change of prime-mover, by EMD as well as GE, is that the only way to make a Series 710 engine produce more than 4350 hp, was to build a twenty cylinder engine…hence, the SD80MAC…some say had the Conrail not merged, they would have bought more of them, however, look at the fact no other road went for them. And, the hp rating stopped at 5000 for that engine. The EMD Series 710, and GE 7-FDL engines are topped out, meaning they will not survive long, if you turn them up any higher than what they are right now.
They say it takes about ten years for the railroads to win over to any new technology.
The Series 265H engine, as well as the Series 20V710 engine, are very much alive and well, in marine, power generation, and oil field power units, as well as an occasional military order.
It’s the same as with the Caterpillar 3512, 3516, 3612,etc. the engines are near perfect in their proven fields, but railroads cannot justify the new technology, as far as training, parts availability, etc.
Even AC technology, proved short for line haul railroading…sure, they have the lugging power, and don’t burn out traction motors at eight miles per hour, after hour, but who has time to go eight miles per hour? This is why the roads are buying ESxxDC and SD70M-2’s. Just make shorter trains, run them faster, and stay out of the way of 140+car coal trainz.
Was there a problem with EMD’s 6000 HP engines consuming excess fuel?How about the GE’s?
[?] Well, replacing two, or more of anything, saves fuel…
I think it was more of a cost prohibitive prospect, and after all the SD90-H, was aimed at Union Pacific more or less to replace aging locomotives.
The ultimate rejection of the option to re-engine the SD90/43MAC, turned both builders back to the drawing board, and the subsequent development of GE and EMD engines, settled back to engines compatible with the existing fleets.
Add that to my last post…AC locomotives, though more efficient, are also(way) more expensive that DC locomotives.
The reason the CP SD90MACs don’t show up in the US, is because CP never upgraded them to meet Tier 0 emissions requirements. Canadian regulations didn’t require any retroactive upgrading whereas the US EPA did, for locomotives of that era. Since both are small groups they are just restricted to Canadian service. CP calls the 4300hp locomotives SD90MACs (9100 series) and the 6000hp SD90MAC-H (9300 series). which is EMD’s terminology for the two variations.
Can’t really tell you for sure. Only saw one while in use by the UP, but the engineer was laying on the horn the whole way past me. Mostly I saw them at KCS’ Deramus yard in Shreveport while they were under lease. But 4-cycles are pretty quite at idle so it was hard to hear them over the EMDs under load-test.
No truth to this story at all, no Siemens diesel locomotive uses a Siemens built engine, the vast majority use what is now called MTU diesels. EMD’s problem is that in the cutbacks following GM’s loss of interest in the locomotive business many of their Engineers left the company. When the new 265H engine was being developed there weren’t enough people to simultaniously develop the new 265H and attempt to updated the 710G. GE partnered with a German comapny Deutz to develop the HDL engine. But Deutz started struggling financially and has since been bought out. GE sued Deutz over their failure to pay for their share of the costs and to assign the agreed amount of personnel. The loss of this lawsuit was the final straw that caused Deutz to sell out. Diamler bought Deutz, Detroit Diesel, MAN, and Krupp diesel engine designs and manufactures them under the MTU label in Europe and the Detroit Diesel label for sale in the USA. GM is supposed to have the bugs worked out of the 265H engine and it has replaced the 710G for Marine usage. With the small number of SD90MAC locomotives out there it isn’t economic to upgrade the 265H engines to current standards so the existing locomotives will die young, all those that the Union Pacific was using were EMD owned anyway, and there is only four on CP, not really a viable fleet by their numbers. The GE AC6000CWs won’t last too long either, at least as built. BHP Billiton has had GE reengine their eight locomotives with 16-cylinder GEVO diesels retaining the 6000hp rating, and CSX is having a small number of their AC6000CWs reengined as well, probably all of CSX’s will be reengined. Only the UP doesn’t seem to see a reengined future for their AC6000CWs, they are assigned primarily to rock train service
John, thanks for the post.
Are these more likely to show up on GEs before EMDs?
Dale, it’s way too early to tell who will introduce them to North America, look at how long it took for asynchronous AC motors to go from testing to production. The first railroad sized Permag Synchronous motors were used under the coaches on the TGV that set the World Speed record. Their performance was so flawless that Alstom is going to use them in their new AGV which will replace the TGV. The motors will have to prove themselves in Europe before any North America company will take a hard look at them.
EMD’s weakness could prove their strength, in that they can no longer afford to develop most of their own heavy electrical gear. As you know Siemens produced the Invertors and Traction Motors for EMD’s SD70MAC, SD80MAC, and SD90MAC locomotives. It appears that EMD and Siemens had a falling out as EMD’s new SD70ACe uses Mitsubishi Invertors and Traction Motors. EMD’s need to innovate and work with partners may work to its advantage, or it’s possible that GE may go first, it’s too early to guess.
This is interesting stuff, thanks.
Who would ever have thought that the SD70ACE uses Japanease traction motors! As good as any i spose.
It was a well kept secret. I saw it once at LaGrange back in the early-mid 90s. Looked ALCo-ish.
The 6000 HP AC locomotives were aimed at replacing SD40-2s 2:1. There were supposed to be the next universal locomotive.
railvidios.net has several vidios of SD90mII 's running on B&P
these are leased power they seem to be running daily
link http://www.rail-videos.net/video/view.php?id=2361
The original “H” engine was the 854H which was in developement during the early to mid 1990’s. It was a 4 stroke design and was to be the replacement for the 710G. However, it was never intended to reach 6000hp (atleast not in a 16 cylinder version) and when interest in a 6000hp locomotive came about developement on a larger, more powerful engine began and the 854H fell to the wayside. The 265H was the end result. For what its worth, had they stuck with previous practice and labeled the engine by cubic inches per cylinder you would have the 1010H. Certainly a large leap over the 710G.
Bryan Jones
Brooks,KY
It’s not true that EMD now uses Mitsubishi traction motors. When EMD was working with Siemens, the SD70MAC’s and SD90MAC’s used Siemens designed inverters and traction motors but all motors after the SD60MAC’s were made in London by EMD. With the split from Siemens, EMD designed their own motor for use with the Mitsubishi inverter which is bigger than an SD70MAC motor but smaller than an SD90MAC motor. All motors are still made at the London plant.
It is also important to note that EMD wrote the inverter control software for the
