Having very successfully fitted a Soundtrax Econami decoder, adaptor board and sugar cube speaker into a Samhongsa CPR K1a 4-8-4 and with it running and sounding really good on DCC, I then tried enabling DC mode running on the decoder programming.
Not at all straightforward as to enable CV12 must be set to 1 (fine, no problem) then CV29 has to be changed with the number being arrived at by totalling the bit weights which are determined by turning each one of 8 separate bits in CV29 on or off.
I enabled Bit 1 (speed stps) which has weight of 2, Bit 2 APS (DC mode) which has a Bit weight of 4 and Bit 5 (EAM) which allows extended addressing (4 figure number address i.e. loco cab number) as opposed to short 2 digit address. Bit 2 has a weight of 32, the three weights totalled 32+4+2= 38.
However when testing on DC power (2 different controllers tried) sound is enabled OK
Sound is so much better with DCC. Enabling dual DC - DCC mode is alleged to cause run away locos in DC.
When I got back into MR, I went with DCC, not sure I would like sound, because of all the naysayers. Turns out I like sound. My only use for DC is to test locos before DCC conversion.
Sorry not an answer to your question at all. You know there are CV 29 calculators? There are a couple CV’s, like 49, which are additive, i.e. unrelated functions, all combined into a single CV.
Just wondering, did you try it on DC before changing the CVs? Most every decoder I’ve seen defaults to allowing DC or DCC operation, and you have to change a CV to NOT allow DC.
I agree that most other decoders do allow DC by default, Soudtraxx don’t unfortunately - even though they claim “operates on DCC and DC layouts” on the packaging!
Sorry, totally misunderstood your initial question.
I assume this lovely locomotive ran fine in DC before you installed the decoder.
This may not be useful but it sounds like the decoder is restarting repeatedly and never gets to the starting voltage required to move the locomotive. Put another way it’s as if pressing the start up function, which on some decoders seems to be F8 (Soundtraxx doesn’t have this feature, F8 is just a mute), never gets you past the locomotive starting up sounds. Except the drivers do rotate a bit before stopping.
It doesn’t sound like a problem with the sounds themselves. Is there a way the decoder synchronization of chuffed with driver movement achieved? Is that out of sync?
I’ve just acquired a Bachmann Spectrum Shay DCC that produces only sounds when fed DC current. Won’t move at all. More usually, locomotives with decoders not responding to DC are just completely dead.
The loco indeed ran fine on DC before I fitted the decoder, it’s still fitted with its original cylindrical can motor and on DCC works perfectly on sound and runs very well.
I reset via CV8 on discovering the problem with DC enabled and read back the CVs which tally with the Soundtraxx manual where given.
I did change CV114 chuff rate to sync better at low speeds (on DCC of course) but but as far as I recall tested the loco DC enabled with the reset CVs but all to no avail.
I do see where you are coming from though, it does seem that for the duration of the chuff period there is insufficient voltage available to run both motor and sound together, once the chuff packet has passed then background sound and motion restarts until the next chuff packet. At least that’s what I looks like to me as well.
I have a photo of the chassis taken before repair showing the original fitment cylindrical can motor. I assumed that as it wasn’t an open frame Pittman type then current draw would be OK for the decoder. I would attach it but can’t figure out how to yet, I will try again.
It’s great to have suggestions and thoughts on the problem to bounce back and forth, who knows, a solution may even be found! {:O)
Sounds like it is shorting or loosing power, but since it’s happening just as it tries to chuff, it could be overloading. What sort of speaker did you use? Correct impedence rating? Nothing fromt he speaker wires touching the inside of the tender? Check with the tender open, SOundtraxx decoders have a visible LED that flashes error codes if something is going wrong like an overload.
I’m using a sugar cube type speaker of 8 Ohm impedance and I watt output, no shorting errors showing on the decoder just the blue OK light though I will recheck and post if it is redlighting as well as the blue light.
Was also going to ask about the power supply, but it looks like it should be fine. Looks like it’s a fairly standard. Some decoders don’t take kindly to pulse power or PWM type power and do odd things.
Hello, I know this is an older post but it came when trying to research a similar problem I’m having. In my scenario, I have a TSU-1100 (diesel) installed on a Proto GP18 (converted to a GP9) and works great in DCC. I enabled DC mode and I get similar behavior where it cuts in/out constant (movement and sound together) when I am operating on DC track. For my DC powerpack, I’m using a MRC Tech3 and I use JMRI to program my locomotives with an older Digitrax DCS50. Did you ever get this resolved? I was going through Soundtraxx documentation and some parts seem to infer that operation may be sketchy when you have a Keep-Alive and enable DC mode. I installed the capacitor that came with my decoder. Did you? I am suspecting that the presence of the capacitor is causing this behavior…
Is the hesitation only at slow speeds? As noted, sound decoder equipped engines aren’t going to work as well on DC because the sound eats up a lot of power before the engine moves. On some decoders, you can adjust some CVs to make it work better, but it’s not going to ever be as good as when it runs on DCC.
[#welcome] to the forum. Your posts will be delayed in moderation for the first few.
Sorry nothing to add from what I said previously. Groups.IO has an excellent ESU and NCE group. I assume there is a Sountraxx group, with different players. That could be another resource for you.
Actually it’s the opposite… the frequency of hesitation gets worse as you increase speed/voltage. At the moment, my layout is in transition. I still have a few locomotives on DC that I like to run until I get time to purchase and install decoders. Some, like the one above I have converted to DCC but still would like that backwards compatibility until I reach a point to stop using DC on my layout. From what I read in Soundtraxx’s decoder documentation is that by design, in DC mode, it doesn’t apply movement to the locomotive until the voltage reaches a certain threshold.
Thank you for the warm welcome and no worries with regards to the delayed posting. So I think I may have an idea to the cause of the problem in my particular situation. So this past weekend, I removed the shell mainly because I wanted to start primer and paint. While the first coat is curing, I decided to just go ahead and remove the capacitor and see if that had any impact. Before I started, I decided to give it another go on my DC test track. This time around it ran smoothly without any stop/go hesitation. So I suspect there may have been so odd short caused by the shell pressing down on something. I’ll be working on reseating the wiring soon. Hopefully that was it!
