engine house problems
Hello, i have an engine house that will fit approx, two locomotives, but im having a problem with not getting any power through the let track going to the engien house, heres something of what it looks like
\ / this is the side that i am not getting any power from
Y
Tim,
try checking the switch. it may be a power routing switch. You may need to run a jumper wire across.
thanks for all the adivise, what did was i just connected the left switch with two regular connectors and put an insulator at the on the inner side of the track, and now im back up and running
[:)][:D][8D][:p][;)][:o)][^]
