engine levels
Glad we could help. i don’t mean to change the topic on everyone but heres a dellema… CP rail, or the AMT owns a lot of different locomotives, some dating back to the old EMD F series, the “bullets” to GE’s AC4400CW. my question is this, and i mean not to change the subject… but what are the outter appearence differences between EMD’s SD90MAC and GE’s AC4400CW? because they look almost exactly alike… i ahve to gamble each time because i don’t know what it actaully is. once inside it has a peice of paper which one it is… KINDA giving it away! any help would be great in “spotting the differences!”
Cheers,
Kev
i have read the posts for this topic, and still don’t get it… what is being applied thru the throttle? is it diesel rpms or electrical current? how much power is added going from notch 1-2? is it the same amount in going from 4-5?
what are the priority gauges to be watched in increasing, cruising and decreasing speed routinely? in reading posts, it seems 3 of the meters to watch are amps, air pressure & speed…
speed is important, because there are restrictions & rules out the wazoo… just as important is engine performance (diesel and electric)… which gauges tell how efficiently the engine is doing? what is the threshold on different gauges that is a ‘red flag’
…like temp. gauges for oil & water in a car?
between the load, the grade & speed restrictions, it must get pretty deep in deciding what to do & when…
it has to be a hard trade-off when pulling out of a yard with a coal train (or equally heavy load)… just when maximum speed is reached, the throttle must be pulled back for a curve, grade, etc… it must put a lot of stress on an engine to work up to pulling a load to maximum speed, only to cut back due to the terrain or populated area, then accelerating again after the restriction is passed… what does an engineer watch for to get thru this o.k.?
Easy identifier, fuel tank on EMD is rounded on the sides, GE has sharp angler sides, with the air reservoir cut into a recession on one side.
EMDs are good looking, GE looks like a lego train.
Ed
Boy Kev, you really gave me the absolute red here. My mistake. And I appologize. To quote you, you wrote “No automatic break valve in locomotives.” Well here is where you show your RRing superiority. And I am glad that I was set straight by you that there are NO automatic brake valves on a loco. Oh by the way Kev, have a great day.
Throttle notches corrospond with pre-set universial engine rpm. Notch 4 on a GE is the same as notch 4 on a EMD. The prime mover, (diesel engine) turns the alternator via a direct drive shaft, more rpm = more amps, more amps= faster spin on traction motors.
Best anology I can come up with is your electric blender. It has 5 or 6 buttons, button 1 allows only a small portion or low amperage to flow to the motor, so it runs slow, button 5 allows all the amperage to go to the motor, it runs fast.
Load it up with bread dough(resistance) and try it on button one, it bogs down, so you “notch it up” to button 5 to get all the power to knead the dough. Same with a locomotive, notch 1 is low amps, notch 8 is top amperage. Once the train is moving, the resistance (inerita) is overcome, and less amperage is needed to keep it moving.
As for stress on the locomotive, these things are pretty tough, add to that the fact that most engineers know the terrain they run over better than you know the street you live on. They know when the grade increases, or rises, where it flows down hill slightly, and react accordingly. I rode with a UP crew once, when we reached track speed, 60 mph, the engineer almost never touched the throttle, he just applied the train brakes ever so gently to keep the train stretched out down hill, and let off the brake, increased the throttle one notch uphill, allowing the inerita to push us over the hills. I never once felt the slack run in hard enough to notice it more than a gentle nudge.
Good engineers know in advance when and where any sharp curves are, the strain on the locomotive is minimun, they allow the weight and mass of the train to work for them.
Stay Frosty,
Ed
Guess telling him what a independent and automatic brake valve is, and the difference between the two, would be a waste of time?
Ed
Slofr8 - I loved your “splainen”. It was just what I was looking for. I figured there wouldn’t be just a certain notch, but hadn’t quite figured out why. And I was looking for some kind of explanation on what determined the “notch”.
We were watching a freight train coming in one day and he was getting pretty slow and suddenly had to come to a complete stop - I think he startled the whole neighborhood! I felt bad for him!
Thanx for info!
Jen
Gentlemen: I appreciate all your answers. I think I now have some idea about the “notches”.
Now I need to go and put all this information together.
Thanx
Jen
Yup, that’s what I was thinking Ed. I guess that ol Kev really “dealt me an absolute red on this one.” Maybe those GE units which means General Electric (thanks Kev for setting me straight on that one, pretty funny coming from somebody that cannot distinguish an EMD, Electromotive Division, from a GE) don’t have automatic brake valves. I guess since automatic brake valves don’t really exist, locomotive air brake tests just got shorter. Set up the ind. release. good to go!
Cheers Ken
Guess your really shivering in your redwings now, having been dealt a absolute red by a expert. And yeah, I though it kinda odd a bigtime player like him cant tell the difference between EMD and GE, so I gave him a cheap hint. Wonder if he knows which end of the train the brakes start setting up from?
Whoops, that would require one of those non exsistent automatic brake valves…I forgot, we still have brakemen, using those running boards on top of the cars to run down the train, tieing hand brakes to slow it all down.
Wanna bet MR DOW(better living through chemicals)
has automatic train stop confused with automatic brake valve?
Stay Frosty,
Ed
Ed, I would be surprised if the expert knew what ATS was. I really dig on your description of the GE (that is for General Electric; O.K. one last shot at Railroad Kev) units. They really do look like a lego loco!
Ken
P.S. Everybody knows that the brakes set up from the middle of the train, that is after you break in two if you just slap the throttle in “speed 8,” or what the rest of us call run 8 like the pro Kev says.
Cheers
jenny
slofr8 was the best person exsplaining most of this, i only have one thing against his statement. now its not to say he is wrong couse i know engineers who do this and it works for him. I dont watch my amps to see them drop before i get another notch. i get what i need. as long as you have your train strecthed it wont break. Now i should also say here that i wont go over 1200 amps when pulling from a start and i dont get all 8 notches either. A perfect senerio would be on ge engines ill get 2 notches right away, then as i get rolling ill get 2 more as it throttles up i might get 2 more and so on till i start gettign to track speed and start notching off. this will also depend on the layout of the land. if i crested a hill ill notch off so i lose some speed and before the rear end gets over the hill ill get a few notches ( this is why i lost speed after cresting hill so i have a chance running away from the slack with out speeding) a good way to see it is lets say you are driving a truck and have a mile of camper trailers behind you. you pull out of a rest area you got it moving and now your on the ramp for the interstate you mash your motor to go and merge into traffic. same thing starting a train. now you just pulled up hill and crested . are you going to keep your truck floored or will you let off the throttle? maybe alittle brake? if you do it right you wont need brakes you will let the terrain do all the work and you will just look goood.
cabforward all i can say for your question is not all engines are the same . you might have 2 ge engines sitting there and notch 1 on one of them might load 300amps. and only 100amps on the other. As far as a water temp and soforth there is none. that is done by the computor and if you lose or get low oil or water level the engine saftey devices will shut the engine down. The gauges will very depending on engineer and where he is running AS far as i am concerned after i have my train rolling i dont care about the amp gauge ill look at it to
Thanx Wabash - I appreciate the information. Sounds like you run and engine like the old heads did - by feel and sound. But I guess after so many years of doing this, it becomes a part of you.
I knew an engineer that used to run a train and could tell the speed without looking at the speed recorder - his young brakeman asked him one day how he knew the speed w/o looking - he jokingly told the brakeman that he counted the telephone poles, pi r squared them and divided by 2.
The brakeman went home and told his wife and they were both so impressed the next time the brakeman saw the engineer he told him so!
Never heard if they ever figured it out or not!
Jen
I think the only thing Connie ever gets is FIRED.
Oh man, dont make me laugh so hard, I was eating tortilla chips and salsa, wow that burns…
Stay Frosty,
Ed
i was amazed at how easy some of the guys made it look when they ran like there was nothing to it when i first started. then after i got on that side of the cab it was differant. now i am training guys and they are amazed that i sit on the conductors side of the cab and can tell them what to do and have no slack action and not let them speed. I learned from ole head engineers and that is what i do by feel. gages tell you what the engine is doing your butt tells you what the train is doing.
pro kev the super hogger. When i went to work last night i had the shop come out and and remove the automatic brake handle as i was told by a supper hogger that we aint supposed to have them on these engines. all i needed to do was go from speed 8 to idle to stop. and hold it with the independant. well i am happy to tell you that after i came back from taking a drug test i finished my tour of duty. It sure makes a person confused when i had enough to do that now i got to figure out weather i need to be in speed 8 or notch 8 or run 8. what that big red handle is for i guess it for hanging my hat on? i sure dont want to disprove him he might put a absolute on me. I wonder what that other handle is for above the throttle i got it to move last night and it made a lot of noise. but i did not go faster just got the train mad at me when i went to speed 8 on it. it must be for the auxilary fan for the hyphadufinator quadumadulater roller bearing valve hooked to the watchamacallit. im sure super hogger will set me straight on this.
Ed, if it werent for you and Wabash and a few others here, I’d never post in this forum again. If you guys are ever in KC drop a line and I will buy the first round!
Ken
P.S. what’s that little stubby lever for? I pulled on it really hard and it came out in my hands. I just threw it out of the window on my big 'ol G.E. (that’s General Lectric for you inferior rails), but, after that, I couldn’t shift through the 8 speed tranny on my loco. Does EMDs have an 8 “speed” tranny? how big is the clutch on those units?
Ed, I’m really sorry! Especially since I made you shoot good Texas salsa out of yer nose. That’s just wrong to waste good salsa! Was down Texas way awhile back to pick up a motorcycle from the H-D dealer in El Paso. Darn that town has some good Mexican food!
Ken
i dont know im still trying to double clutch these things that is why i blow that horn to cover up that noise from that tranny.
