I wish manufacturers wouldn’t glue engineers in dummy units. They really ruin an otherwise good looking lashup. These guys are really bonded to the shell. Anybody have a safe way of extricating their little carcasses without distorting the shell? I was thinking of turning a dremel grinding wheel loose on them!
You’ve never seen invisible paint?! Your local hobby store should have it in stock. Paint it on the figures instead of grinding them with a Dremel tool. Jim
Despite all the flippant replies, Rich makes a good point. The manufacturers could save a few cents by simply eliminating cab figures from dummy units (which would then tick-off those who operate A-A combos with the dummy unit facing forward). Seems like it would be one of those darned if they do, and would be darned if they don’t situations.
In the past, I’ve simply used an X-acto knife with a new (sharp) blade to make such modifications to locomotives I’ve had where I wanted to remove or replace the cab figures.
Like Allan suggests, some operate the dummy A up front. Perhaps it would be best if they made all engineers capable of being removed without too much difficulty. I would like that option. Of course, I like mostly steam and post war, so I have to add my own figures.
Since a dummy is just a car masquerading as a locomotive, I generally run dummies first, to minimize the number of cars behind the real locomotive that are available for “stringlining”.
If you run the engineered dummy up front and presumably the powered engine second in the consist, wouldn’t you have the same problem: a little figure in the 2nd engine. It’s like my Western Hobbycraft trolleys have a motorman on both ends - I like it though - the interurban’s in such good shape, they have conductors or two-man crews
I still can’t understand why a loco sold individually as a “non-powered unit” doesn’t come with even the most rudimentary functioning lights. [2c] [|(]
I run dummies in themiddle of the lash up due to the electro coupler thing. I could add them I bet. I have added smoke and lights [with off/on switch] to mine. Was easy to do. That way I can run it up front as the lead engine.
Allan, Maybe you could share a picture of a lash-up on your layout so we might be able to concur with your opinion. Here is yet another lash-up on my layout. I would be all for having the figures removable rather then not there at all.[(-D]
(Tom, You’re going to have to “click” on the picture to enlarge it.)[;)]
