In the hobby of model railroading ones spare living space determines what size of layout that they can design, work with and build. However even those with large enough spaces, dont have to design large layouts as they can be hard to maintain with so much space and track to paintain that comes with a larger layout.
However how could one, estimate or plan a layout that fits their needs, as well as what space they would need and could work with, even if they dont have the space they truly want to accomplish it, or are just not sure?
For example, my space avaible is 14’ x 17’ but there is a starwell and door next to it, and a wall that needs to be taken out. It will be renoed in the future so making a layout isnt the top priotiy.
My goal in the long run is to have a layout with radious curves around 40’ and 42’ curves as I really like the realistic look trains have on realistic curves, with their front couplers being perfectly center on the track, rather they swaying outward and long freight curves that dont look like they are swaying over the track sides or extending outwards too much.
I understand that this might be a difficult approch to estimating what space you truly need rather then want, as your livng space determines that, and when house searching for a sutable spare space that can be difficult as well, as for ever model railroader spare space is a highight.
I wanted to run prototypical Amtrak Superliner trains. They said 15" was fine in N Scale. I bought a circle of track and realize they were wrong, you still had overhang. By reading more it states that I would need like 22-24" or more radius curve and bigger turnouts for the passenger diagrams.
I have the space or desire to expand the curve radius pass 18". 15" will do fine with Superliners, Auto Racks, and 89’ flatcars.
It’s the matter of overhang. In the beginning of railroad planning I wanted no overhang. The main reason was passenger operations.
So as time went by I realized/ noticed I don’t really need broader curves passed the 17" radius. As long as I don’t need to expand the couplers on the locomotive to the freight cars I’ll be fine.
Second somehow I don’t noticed the overhang on 89’ flatcars with trailers and I do notice it on auto racks. Not as much on Superliners.
I started out with about 1200 square feet, but other family considerations quickly whittled that down to about 560sq. ft., in an unusually shaped room with 10 corners…
My original track plan, simply a sketch, was tossed and I moved the already started benchwork into the new room.
I continued building benchwork and open grid tabletops until it circled the room, then cut 2 or 3 sheets of 3/4" plywood into arcs of varying radii, from 30" up to 48".
Next, I joined those pieces together, and chose the largest arcs that would fit into each corner, leaving room for scenery and unknown structures, where possible.
After that, all that was left to do was simply connect the curves with straight-ish track.
In my opinion, the layout is much better and more interesting than the one sketched out for the entire basement.
I was curious because I will have enough Kato models to build a prototypical Amtrak California Zephyr in N scale: 2 F40PH’s, 2 baggage cars, 1 ex-El Capitan transition coach and 11 Superliner cars.
Or enough time. I keep hitting the wall trying to build my 15x33 HO layout because my wife always has a long list of house projects whicn never ends. I’ve gotten about 8 or 9 months of some partial weekends out of the past 18 months.
That’s why God invented unfinished basements. [:P]
In model train layout design there is only “want”. There is no “need”. I think I heard Yoda say that.
If you want 40+" radius curves and a long mainline run, then you are going to WANT a large space. My current layout (being disassembled as we speak) is in a 28x32 ft space but I had to go to 3 levels to get the broad curves (40"+) and long mainline run (500+ ft) that I WANTED.
First question: Are you planning in staying in that location in the long term? Building something to fill that space would take years for a typical model railroader. If not, consider a smalling portable layout.
Assuming you are staying there for a long time, I would approach it incrementaly, like Wayne suggests, but perhaps starting with a small dog bone shape, with a plan to expand. DO the large plan to see how it can be expanded, but consider building the dog bone first to get you going. The dog bone does not need to stay in its integrity in the final plan - part of it can be dismantled at some point in the expansion. Planning is the secret and the loop will keep you motivated. I for one needed to see trains running fairly quickly as fixing old locos is my favorite part of the hobby.
I was building a large layout. A few times along the way, I paused briefly to look at how much I’d done and how long it took. I found that long-term I spent about a month to do one square foot of layout. That’s everything, from benchwork to buildings, building kits, laying track, wiring, the whole kit and kaboodle. Time was everything, too, grocery shopping, raising a daughter, going to work, skiing, bicycling and all.
This, for me, was more of a retrospective analysis, because I thought I’d have my first 5x12 foot layout section pretty complete and presentable in 7 or 8 months, when in reality it took 5 years.
Other than having to sell the house and move away, this kind of worked fine for me. I never got to the point of being tired of the layout or the hobby. I always had more to do.
But, carefully consider how much time you will have to spend, and how much you want to spend on layout building. I built my layout in sections which I pretty much finished before starting another section. Each section carried with it a satisfaction of completion.
Regardless of how much space and money you think you have to dedicate to your railroad I suggest you start small and start with an operable subsection of whatever dream layout you think you can build.
Nothing is as discouraging as working away and ending up with nothing that can run a train until it’s all finished.
Building a model railroad is a LOT of work. Far more work than it seems it should be.
Building a model railroad is also much harder than it seems it should be.
Building a good model railroad is a lot more expensive than it seems it should be.
Start with big ambition but modest plans is my advice.
What layout builder never wanted more space? I’m not saying that no one is happy with what space they have. I am saying that each of us - secretly or not - has imagined what they would do with more room.
Who hasn’t lusted for a long staging area, or turntable facilities, or that long main, or an “off the main” logging or mining sub, etc., etc.?
Thank God I don’t live in California anymore, as much as I miss it.
So true! I used to work for a government agency and one of the government employee’s had this tag in every email sent:
“There is no try, only do!” - Yoda [:D]
I wanted 40+" curves too, but in the high cost of living area the best my wife could find me was the basment which we finished ourselves in the photo’s above - an odd shaped space about 15x33 (excluding the far room by the walk-up doors). But I also wanted a “decent” mainline run so I had to settle for 32" minimum curves, although they only come down to 32" in 2 spots and a bit larger elsewhere, mostly in the 34 to 46 inch radius range.
This is mostly a single level but a large staging yard under the main yard and a branch-line below the mainline (partial 2-deck?). I wanted to keep it “managable” due to my lack of hobby time as the house is a fixerupper and my wife has ongoing plans.
Great stuff everyone! Starting small is the right way to go and then building up. I did that on my 1st layout and the 2nd one is much easier to handle. There’s no way I could avoid feeling intimidated with the size of the 2nd had I not followed this approach.
Building the layout to accoodate your needs is paramount. The time, money, energy spent on it is worth the joy of seeing young kids marvel at the work. Seeing another’s jaw drop when you show them your work makes the effort worthwhile.
Estimating the layout space you truly need, rather than want?
That’s the title to this thread, but I don’t know what it means.
Estimate the layout space you truly need? My basement measures 60’ x 34’. That’s what I need.
A 100’ x 100’ outbuilding. That’s what I want.
A model railroader is incapable of estimating the layout space that he truly needs. How would you calculate that?
A large layout? Be careful what you wish for. I started out in 2004 with a 4’x 8’ layout - - a simple oval. I needed more. So, it quickly became a 12’ x 8’ layout with two pop up holes in the middle. I needed more.
Fast forward to today. My space is 42’ x 25’. It has taken me 3 years to demolish the old and build the new. It is too big. I cannot manage it. I have way more locomotives and rolling stock than I can operate as a lone wolf. I am constantly selling off like new equipment because I cannot use it.
I find myself currently planning my next layout which will be a downsized 24’ x 12’. There will be few turnouts and lots of hidden staging. The 130’ turntable and 9-stall roundhouse will be eliminated. The 10-track downtown passenger station will be a thing of the past. No freight yards or coach yards. Gone will be the engine servicing facility. No spurs, no sidings.
My objective will be to sit on a chair, beer in hand, and watch trains run. My current layout is designed for operations, but I lack the desire or motivation to conduct operations.
