What ESU sound decoders will I need for the Athearn RTR GP60M, GP40X and GP50’s
Ch
Ch
I think they only make one, and you have to load the sounds for the individual engines into it with your own PC and programming interface, or order the decoder with the sounds already installed by someone like Tony’s Train Exchange.
Actually they make 3 - Loksound Micro for N scale, Loksound for HO, and Loksound XL for large scale. Only one is suitable for Athearn HO. All are direct wire - which is NOT that big of a deal.
Oops, actually they make FOUR - the Loksound mfx for Marklin is the fourth.
82404 EMD 16-710GB 16cylinders, dynamic brakes, Nathan 3chime air horn GP60, GP60M, GP60B, SD60, SD60F, SD60M, SD60I, SD75M, SD75I
82405 EMD 16-710GB 16cylinders, dynamic brakes, Nathan 5chime air horn GP60, GP60M, GP60B, SD60, SD60F, SD60M, SD60I, SD75M, SD75I
82406 EMD 16-710GB 16cylinders, dynamic brakes, Leslie 3chime air horn GP60, GP60M, GP60B, SD60, SD60F, SD60M, SD60I, SD75M, SD75I
82407 EMD 16-710GB 16cylinders, dynamic brakes, Leslie 5chime air horn GP60, GP60M, GP60B, SD60, SD60F, SD60M, SD60I, SD75M, SD75I
72486 EMD 16-645F 16cylinders, turbo charged, dynamic brakes, Nathan 3chime air horn GP40, GP40-2, GP40-2L, GP40P-2, GP40X, GP50, SD40-2, SD40T-2, SD40-2SS, SD40-2F, SDP40F, SD40X, SD50S, SD50, SD50F
72487 EMD 16-645F 16cylinders, turbo charged, dynamic brakes, Nathan 5chime air horn GP40, GP40-2, GP40-2L, GP40P-2, GP40X, GP50, SD40-2, SD40T-2, SD40-2SS, SD40-2F, SDP40F, SD40X, SD50S, SD50, SD50F
72488 EMD 16-645F 16cylinders, turbo charged, dynamic brakes, Leslie 3chime air horn GP40, GP40-2, GP40-2L, GP40P-2,GP40X, GP50, SD40-2, SD40T-2, SD40-2SS, SD40-2F, SDP40F, SD40X, SD50S, SD50, SD50F
72489 EMD 16-645F 16cylinders, turbo charged, dynamic brakes, Leslie 5chime air horn GP40, GP40-2, GP40-2L, GP40P-2, GP40X, GP50, SD40X, SD40-2, SD40T-2, SD40-2SS, SD40-2F, SDP40F, SD50S, SD50, SD50F
Forgot to add, I got this from tonys’.
Click on products
then ESU
then loksound ( not micro or XL )
