I was told that the new CREATE FX paint sticks / markers are the old Floquil paint colors and are made by Testors.
Scalecoat II had not one but two of those - Grimy and Grimy 2.
I’ve exhausted my supply of Floquil Reefer White spray cans. The Testors white is too…goopy and bright white. Does anyone know of a good spray can white?
I will say it once again, I don’t miss floquil because I stopped using it several decades ago in favor of Scalecoat and Scalecoat II.
As for acrylics, no thank you except for a little brush painting on structures.
No acrylics for my airbrush as long as I can get solvent based paints…
Sheldon
My understanding is the grey contains a scratch filler. So, yes it would cover better as it is a thicker consistency.
Interesting, and would fit with what I experience. Thanks.
Does the Model Master grey enamel primer have the same sort of filler? I will need something to brush paint on small, unpainted details when the Floquil finally runs out.
Never used Testers. You could go to a auto parts store and get primer with a scratch filler. It comes in other colors besides grey. It will be in a spray can clearly marked. Try spaying some into a container, let the carrier flash, then see how it brushes.
Ebay has unopened bottles of Floquil so thats a option.
I don’t mean to hijack this thread but it seems likely to be of help with a real problem I’m having; painting plastic structures using Testors enamel. I must be doing something wrong because it take 3 or 4 coats to cover (mostly white plastic) and the paint shows brushmarks badly and over all the paint looks terrible. If I thin it, it seems that I would nee many more coats to cover? I am painting trim like doors, window frames and such. Any suggestions would be appreciated.
