Thanks for your input and concerns. I’m not opposed to corrections in the layout as long as my requirements are covered. Any help would be greatly appreciated. My design was based on the following criteria:
HO layout, no reverse loops, turn-outs, crosses etc, at one point two tracks need to be close and in opposite direction (on mine, it’s the lower left corner) so the station can be placed inside the loop and the platform can be between the tracks to allow passenger travel in both directions, most of the curves should be 18" radius minimum, using EZ Track, the whole layout is one town, it should be as compact as possible (the smaller the better), try to have a little variety in outer perimeter as mentioned by Texas Zepher, include a single unconnected loop inside (can be 15" radius).
If these can all be met in another design, I’d truly be grateful.
Given that you’ve created what you want, my only concern would be with the grades required. As long as you stick with short trains and have good vertical easements (ask if you don’t know what that means), you shouldn’t have much trouble. The problem is, EZ track makes it tough to get anything but an abrupt angle at the beginning / end of an incline.
Thanks - I’ll definitely have short rolling stock. The 4-4-0s are short, as are the period passenger cars. The trains will only be 2 or 3 cars long. Should be OK (but I will test before anything final).
Sorry - I don’t do track planning with sectional track - it is just too limiting to be fun for me.
In principle, I would think that a plain double track loop on a 4.5 foot x 8 foot table would work. Small back drop 2 1/2 feet in to hide the rear of both loops.
Have one train run clockwise on one track, another run counterclockwise on the other track, with the station platform being where people transfer between the two trains.
Automate things, so the one train (say the DeWitt Clinton - the replica the NYC built in 1893, not the original scrapped in 1833) comes into the station and stop at the rear side of the platform. Then another train (the 4-4-0 pulling some passenger coaches) pulls into a track on the front of the platform.
Hidden by the front train, a group of passengers appears on the platform (maybe the platform flips or something).
Then the front train departs, runs behind the backdrop and stops.The crowd admires the DeWitt Clinton, before the DeWitt Clinton backs up around the curve (and in behind the backdrop). Then the DeWitt Clinton makes a new appearance, steaming past the platform and around the curve on the other side.
After a bit, a gandy dancer comes through the backdrop
though i am not 100% sure, i thought a gandy dancer is a nickname for a track-worker on the railroad,
not for the small piece of equipment used to facilitate their job.
A few remarks about this thread so far:
for a newbie FunSC has very strong opinions. No problem for me at all, the problems arise when he might develop a different view a few months from now.
Your choice for a layout without turnouts and 3 completely different “loops” is remarkable. With a few turnouts you could connect the independent loops, which would make your plan much more versatile. Adding the possibilty only, to get a layout where some switching or dispatching still is an option in the future, is not a bad thought.
Your choice for a layout as small as possible is remarkable too, as if you do not like the building nor watching at your trains very much. The very same applies for your choice to have just one scene.
Your responses are very clear; almost as if you want to end a discussion before it even has started. Like : “it’s my choice, period”. IMHO the best reason to stay away from this thread.
I would like to see not only a plan for your tracks, but also how you envision your scenery; e.g. the placements of roads, streams, tunnels and buildings.
I suppose I could have called what I (and pops) was talking about by it’s full name : “gandy dancer hand car” - ie an animated model of a one or two workers on a hand “pumped” car, where you see the workers pump up and down as the car moves:
Stein - Thanks for the reply. My thoughts - first the specs did come before the plan. (LOL) Next - I totally understand this type of project not being fun for you, and that’s fine. I’m not trying to create “work” for anyone, just discussing what I am trying to do. I appreciate what you’ve contributed so far. In fact, because of the responses here, I’m in the process of revision 6 gazillion and 2. I’ve eliminated the reverse tracks with the gandy dancer hand car. So far, I’m down to 5x8 and still trying to get a little more off.
The scenario you created is really cool. Sounds a “little” over my head at this stage. [*-)] Perhaps after I learn a little more, and better my finances a bit, I’ll add a second 4-4-0 and try to automate a stop at the station for both east and west bounds at the same time.
As I finish this next draft, hopefully by tomorrow, I’ll post it so all can see my changes.
You’re absolutely correct about the name gandy dancer. My mistake for not using the full name as Stein mentioned.
I’m sorry my opinions came across too strong. I have been planning this for over a year now (started in November, 2010) and am finally getting close to start building. I understand my choices are completely remarkable to you (and most here). We’re just coming from two different outlooks. And I assure you I’m not trying to end the discussion - on the contrary, I truly appreciate every bit of input.
I guess I should explain where I’m coming from with this plan. I’ve hesitated to, because I know a lot here won’t take me seriously. But, at the risk of starting flaming posts, here’s where I’m at.
I’ve been a collector of Department 56 villages for 18 years. All that while, I’ve had displays up, building and rebuilding the scenery, and updating with new buildings. I collect the Heritage Villages, which are different and smaller than the Snow Village commonly used with toy trains. I mostly have Dickens Village, and a few of the other villages under the Heritage Village banner, such as New England Village, Alpine Village, North Pole, etc. Hence the name Heritage Valley Railroad.
While I have an extensive building collection, I don’t use any of their accessories, people etc. I like to keep everything in scale. That makes me “different” to other D56 collectors. This puts me in kind of a “no-man’s land” of collecting now. For 18 years I’ve had displays without trains and have had no ambition to run operations. The trains are just another, and new, aspect of my display. But that doesn’t mean I’m not taking it seriously. The fact that I’ve been planning for over a year to totally build a new display should say something about why I have opinions, needs, and wants, but above all, this is how I have MY fun.
I’m sorry you feel you should stay away from this t
Hey - no problem. I am not saying that I find your project painful to discuss - merely that I personally dislike trying to make track plans with sectional track - I find sectional too confining for my taste.
I used sectional when I was younger - German Märklin brand track - very robust and bullet proof, very few electrical issues - since they used studs along the track center and a pickup under the locomotive for one of the electrical feeds, and both rails as the other polarity - no challenges with reversing loops or having double ended sidings or anything, and tons of track plan books which listed what tracks you needed to build the various configurations, lots of accessories for automatic reversing, slowing down at stations and so on and so forth. And pretty much anything went around 14.75" curves, even in H0 scale. And stuff pretty much works after 20 years in storage - after doing a quick oil change and cleaning of gears. Sectional definitely has it’s place.
If I hadn’t found this discussion interesting, I wouldn’t have taken place. So don’t think about you creating work for me or anything like that - if anything, I am sorta jumping into your thread because I found the discussion interesting.
[quote user=“Fun Senior Citizen”]
I appreciate what you’ve contributed so far. In fact, because of the responses here, I’m in the process of revision 6 gazillion and 2. I’ve eliminated the reverse tracks with the gandy dancer hand car. &
Thanks, Stein - That’s why I’m here - it’s fun to interact with you guys, plus, I always learn something.
Don’t worry about anything - you aren’t “forcing” me into anything. As paul pointed out, I have “strong” opinions. But, the point about reaching 3’ is obviously valid and logic wins out. I was forcing too hard to get that gandy dancer in. It is a better layout now without it and it still meets all my original requirements.
Thanks to all of you guys.
[tup] [bow]
The updated layout is in the photo gallery - “Pops Plan 2”
Not your fault that the people who make the forum software (i.e Telligent) hasn’t thought of including an obvious “get image link” link or button on the gallery web pages - I just figured it would be easier for people to find it the image if I added a direct link, instead of having people look through the gallery.
Track plan seems essentially the same - little narrower, the third point-to-point track is gone, but otherwise it looks pretty similar.
One thing which may be worth trying is to either draw in buildings, roads etc (as squares) on your plan, or to do a full scale mockup of the entire layout in cardboard, so you can see how scenery and buildings etc will work with your track plan.
Yup - it’s a lot easier that way. The easier it is to find things, the more will take time to look.
Yes, the track plan is essentially the same, but a foot narrower to help a little with the potential reaching problem. Besides taking out the gandy dancer reverse track set, I also smoothed out the left side outer line a bit, to make the incline a little easier. The hardest part for me was changing a bunch of the sectionals to make the new version come out right. (a problem you don’t have with flex track)
As to the rest of the layout - two parts are fixed, and determined part of the track design. The main station will be inside the left loop at the bottom center, with the platform between the two tracks. The train store/station for the historic train rides will be inside the inner loop on the right side, beside the straight track. The rest will be trial and error. Most of the left side will be at the 2.0 level, and the right side and back of left side will be at the 6.0 level. The two tracks on the left will each go into a cut with almost vertical walls. Leaving the left loop will go into a tunnel under the right loop.
I have over 90 buildings (but I won’t be using all of them). Which ones, and how many will be based on placing them on the layout and moving them around to get the placement I like the best. generally though, inside the left loop will be a town on a couple of levels. The right side will be like the outskirts of town. More room, a couple of mills with water wheels, and a few pubs/breweries. There will be a stream running from upper right corner to the lower middle area. The exact location will be determined by trial and error.
The most fun for me is picking and placing the buildings. Once I’m happy with the final placement, I draw an outline around each one and label it on the foam. Then remove all the buildings, do
In your initial posts in this thread, you asked questions like whether EZtrack was used for “serious layouts” and mentioned that you, while not being a rivet counter (i.e. extremely focused on things being 100% correct) were “not into the look of toy trains either, but somewhere in the middle”.
Which several of us probably interpreted as you wanting to model some elements of a railroad, but perhaps without extreme focus on getting every little detail right - more creating a somewhat realistic impression of a railroad.
But looking at your station building, it looks like one of those pretty stylized porcelain buildings people buy to put on their mantlepiece at Christmas time to create a “Christmas Village”.
If I make the assumption that your main goal is to put some moving trains (where the locomotives and cars themselves do not look like caricatures) into a largish animated Christmas village display, rather than to create an impression of a railroad or railroading (functionally or visually), then your track plans also makes a lot more sense.
I may be interpreting your goals wrong - but would it be fair to describe your overall design goal as creating a large permanent Christmas display you plan to leave out all year around?
Well, yes, and, no. Yes, it will be using Dept 56 buildings (that’s my main collection and what started this) but, no, it won’t be a typical Christmas village either. The HO part I plan to do to the best of my ability (such as it may be) to be correct for December, 1880. The buildings will be D56, not kit built or scratch built. However, people and scenes are to scale, no Santa Claus flying over head, and no elves skiing by. So, in my mind, in not just a typical Christmas village, nor a typical model railroad or toy train, but a depiction of life in a town in early winter. To me, it seems to fall in the middle of everything. And yes, this will be a permanent, year round layout.
You can delete that long URL if you want, I did mine, and we won’t need a six foot wide post - [:)]
