As anyone who is following my series here on FasTrack knows, I want to totally convert to it. What a terrible mistake it would be to convert to the new track only to find that Lionel hasn’t thought of everything.
So far, it looks like 2004 is going bring a lot of cool FasTrack! Just look in the new catalog! But here’s a question: What about making blocks? With the tubular track, you just replace the CENTER pin with a plastic (fiber) pin. I have not seen plastic pins for FasTrack, only insulated sections. As you guys know, the insulated sections are great for activating accessories and have the outer rails isolated. Will Lionel make plastic pins for the CENTER rail?
Even with Command Control engines (each having different ID numbers), you may still want to control different blocks. For example, I have passenger cars on a siding that do NOT have on/off switches for their interior lighting. So without a separate block control, the lights would come on the cars everytime I turned on the layout’s power. Just another thought here…
ATJ
