Fastrak switch and DCS AIU hookup help!
Can’t figure it out! I had it working but switched was straight and straight was curved. At least I had it working! How should this be wired correctly? I am using track power and using the ports for where the Lionel switch controller was hooked to! I have tried all combinations some only switch one way some don’t switch at all! Am I overlooking something?
Hope help is on the way! Thanks!
[#welcome] marty w,
The AIU has three terminals screws that you should hook up to, 1 & 2 control the turnout direction and N gets powered by the negative wire according to MTH instructions. If I am correct the Fastrac switch should be wired like an old 022 switch if so the center terminal on the switch should go to N on the AIU and the 1 & 2 terminals get the two outside wires, don’t worry about the hot wire as it should be pre-wired in the switch assembly.
I am using GarGraves track & switches and have to wire a little differently than for Lionel switches.
Lee F.
FasTrack certainly has its share of challenges that separate it from other types of track systems. With this in mind we have started a group specifically focused on FasTrack. Issues such as this are addressed. Why not take a look?
Season’s Best to All, Mike
Lionel_FasTrack_System Yahoo Group
( http://groups.yahoo.com/group/Lionel_FasTrack_System/ )
