It always amazes me that a BB that is so dedicated to the operation of Lionel Trains still has the majority of the people standing in the corner of a track system that was designed in 1915. I stated this time and time again, companies do not work backwards. Products designed in 2003 (FasTrack) can not be any worse than something made in 1915.
I am an operator and some like me choose to blend Lionel Trains with scale structures (like ALL Lionel showroom layouts of the past/present). I am not defending FasTrack, just trying to remove the blinders that a majority of the operators here have.
Off the shelf look. Look at the difference between tublar and FT! No comparison. FT is 10x more releastic. “Fixed” up tublar could never look as good as a piece of FT. Does FT have unsightly UTC lockons? Closely spaced ties on FT with balast, and no need for extra $$ and about a hundred hours sticking wooden ties unrealstically next to metal ties and adding 20lbs of balast and glue.
Every look at the tublar closely? The crest of the rails is rounded and thin! Ever look at FT? Its flat and wide! FT simply offers 10x better surface area for the rollers (all 3 rails). Check out a Lionel passenger car. Put it on FT and see the lights stop “flickering”.
Radius and other options. Starts out at a much more realistic 36" curve. 5" doesn’t sound like much but it is. Does tublar come in 60" or just awesome 84"? 1 3/4" sections? (the list goes on) NO. Does tublar have Wyes? The options are FAR greater and WILL be growing with every passing year.
The FT switches are the best part. NO light bulbs. It is so nice if fixed volatge is not being used on tubular switches. FT switches have LEDs. The truely BEST part is in almost 100 years, Lionel actually produced a switch that is the same height as the track it connects to! What a treat! Instead of seeing a 773 Hudson going over tublar/tublar switch connections and looking like a ro
