faux metal
I am going to have an extended elvated section of track on plywood and tressels. I want to dress up the sides of the plywood and maybe make sides. I have seen faux brick at scenic express. Has anyone seen faux metal siding?
thanks
Evergreen Plastics and PlastiStruct make styrene in various shapes/textures, including aluminum and wooden siding.
http://www.evergreenscalemodels.com/
http://www.plastruct.com/
Do you mean metalized-plastic sheeting or do you mean a metallic paint?
Andrew
I was looking for some platic sheeting that looks like metal. The sites listed above are helpful. I would ideally like to find something with straight vertical lines with little rivets. I have seen it done in magazine pictures. I assume I would have to use some kind of thin wood as backing to make the sides functional in case of an accident. I am using 72 inch curves so it should not be much of an issue.
Thanks
Fine Scale Modeler has done several articles on making rivets using sheet styrene. They have their own web site and forum:
http://cs.finescale.com/forums/
Link to a web site on “rivets”
http://www.largescaleplanes.com/tips/RatoMarczak/riveting_1/riveting_1.html
I’ve used the dressmaker’s transfer tool (looks like a mini toothed piza cutter) on thin styrene with decent results.
