Feedback on Woodland Scenics Foam
Has anyone ever used the 1 to 4 inch foam manufactured by Woodland Scenics? If so, I could really use your feedback. Thanks!
If you plan on using the WS foam as the base, I would suggest insulation foam available at Lowes, Home Depot, or the like. Price the two to be sure. I got mine at Lowe’s.
The WS foam inclines are very nice. I used them on my last layout. Easy to cut, curve and glue. If you want a 2% that is what you get, no measuring.
Good luck,
My entire layout is fastened down on the WS foam. I put the foam down with contact cement using a 1" roller. All my track is soldered (the foam allows the track to expand). I placed track leads for each meter of track and used track joiners. I’ve had no trouble with the track for several years. Bob Whitten
Thank you very much for the feedback. I think i will use the foam on my layout.
