Used to be able to find in bulk (50lbs. plus) at a building products place now closed for several years. Need a source in Eastern PA. Any ideas?
Tommy Gilberts hobby shop in Gettysburg stocks 50 lb. bags. Call them at 717-337-1992 or E-mail at tghbyshp@cvn.net. If Gettysburg is too far for you to drive, they may send you some.
Matt
Send an e-mail to: usg4you@usg.com and request the name and location of the dealer/distributor nearest you.
Also check with a ceramic supply place. They sometimes have it and use it to make ceramic molds…Vic
Also, you can ask for UltraCal 30. It is a different manufacturer and is slightly gray in color. I prefered it when I was using hardshell.
Roger
Thanks very much for the info Vic.
Thanks Roger, I wqill check it out. Why do you prefer it to Hydrocal? Where is it available?
you might want to check also,small amount.
1/2 Gallon - Dry
Walthers Part # 785-1201, p. 400 Walthers 2002 HO Scale Reference
A scale, $7.98, currently in stock at Walthers
I prefer it for the gray color. If scenery gets chipped, you don’t have white starring at you. It mixes and sets up just like Hydrocal.
I got mine from a commercial builders supply house.
Roger
