Finding the right paint color.
First off, does Testors make a Spray paint thats very close to or the same as Floquil Caboose Red?
Also, I’m looking for a yellow close to this
http://www.railpictures.net/viewphoto.php?id=71249
http://www.railpictures.net/viewphoto.php?id=71883
http://www.railpictures.net/viewphoto.php?id=135185
Which one of these would be closest?
http://www.hobbylinc.com/htm/tes/tes2917.htm
http://www.hobbylinc.com/htm/flo/flof130031.htm
http://www.hobbylinc.com/htm/tes/tes1214.htm
http://www.hobbylinc.com/htm/tes/tes52910.htm
Thanks
Dingy:
WHICH ‘CORRECT’ paint color?
a.Fresh out of the shops? b.Sun faded? c. weathered, or d.road grime?
REFLECTED LIGHT: e.Noon daylight - full sun? f.Cloudy bright/ overcast? g. late afternoon / side lighted? h.shade?
When you go down to the freight yard as I did, hold up the model under the same light. You will find few cars the same color. Armour Yellow fades toward white the longer it sits in the sun. I’d try a mix of Armour yellow & white
You want an overly simple answer to a complex problem.
OK, try a can of Foquil Armour Yellow. It should dry to a typical outdoor non-sheen, unless you want to apply decals.
Yep… That paint scheme looks like it’s inspired by the Borg paint scheme. In which case it should be easy to do-- UP Armor Yellow and UP Harbor Mist Grey.
It doesn’t appear anybody offers Armour Yellow and Harbour mist gray in spray paint[:(]
Scalecoat makes both colors in spray cans.
http://www.weavermodels.com/page7.html
Thanks for the link.
