I have an n-scale intermountain F unit painted the southern pacific black widow scheme. The problem is I have left fingerprints in the factory finish when cleaning the wheels with Isoprophic Alcohol. I realized the dangers too late!
I am thinking by weathering the unit I can hide this… but I also thought I should treat the damaged areas first. I am not sure where to start. Any suggestions?
You might try a bit of light sanding with 800 or 1000 grit sandpaper before weathering. If you were using 90% alochol. the moisture on your fingers has dissolved the paint. 90% IPA is a good paint stripper!
