First EMD Tier 4 Test Locomotive Released
The first EMD Tier 4 test locomotive has been released for field testing. This is a SD59MX, a SD60M with the 12-cylinder ECO upgrade.
SD59MX Tier 4 Test Locomotive
A UP SD70ACe with similar modifications has been spotted at EMD LaGrange, IL.
I noted several remarks of it being “ugly”…?? Simply looks like something of brute strength to me as appearance. From the photo, it certainly looks long…Perhaps it’s the photo doing it to me.
Engine is being transported as a revenue move from Patterson, GA to Blue Island, IL
I think it does look “UGLY”, with those 2 big humps in the middle. I think they Dr Frankestein aka Gene Wilder to operate and remove them.
Looks like someone tried to run it under a bridge that was too low…
That huge aftercooler on the engine section is what happens when you add EGR to Heavy Diesel Engines. That is the EGR cooling system needed to meet tier 4 requirements for the EPA. OTR engines had to add another smaller radiatior in with EG when they got them. Now what happenes to metals when exposed to Extrmely Hot corrisve gasses like Sulphric Acid or others like them. They Corrode and BLOW apart. Then what happens to oil mixed with water turns into Mayonasse and plugs every oil passage in the block and BOOM. EMD and GE will not be wanting to add EGR in about oh 6 months after they startblowing up sky high in regular service. If the OTR boys are eliminating them on the NEW MODELS maybe the Locomotive guys need to take a closer look at what they are doing. Sorry this is time they have to make a redusction that requires anykind of aftertreatment look at an industry that has been doing it for 7 years now THEY have it figured out.
The most glaring clue as to the Tier 4 model is that no railroad will be able to put its name on it. Look at all those engine door louvers!
…Picky…Picky
Well, at least I have a decent chance at ID’ing the model correctly, after many years of confusion . . .
Or as we say in the OTR side how can you tell when someone is running EGR look at teh SHOPS they are always THERE getting repaired.
Looks good.That thing in the middle sticks out like a sore thumb.
Ed, wouldn’t the alternative be SCR(Urea)? I thought the locomotive builders wanted to steer clear of that?
On farm equipment scr requires an extra tank. is added to carry the urea
SCR in the OTR industry has been a GODSEND to meet the EPA regs. Why has it been that MPG has gone back trhu the roof 2010 models the last models before SCR was mandated were lucky to get 5 MPG. Now with SCR the same speced trucks without EGR are getting 7 MPG and the RELIABILITY of the same engines is back to what they had in 1999. Now hard to belive we dumped one system off an engine EGR and got back all that reliabity and Fuel Mileage we lost when the EPA did the Emissions reductions. Cummins tried something and it worked got rid of the EGR system for 2012 with their SCR system. Or as the drivers are saying now I fill it up with the Hog Pee I stay out of the SHOP. The biggest tell is the Large Fleets the ones that had REFUSED to order new trucks are going back to order new trucks with NEW SCR equipped engines. Schineder JB Hunt Swift all of them are REplacing their EGR equipped engines with SCR non EGR as fast as possible that should tell you something. SCR with DPF is the way to go to lower Emissions in Diesels. BTW that is how they have been doing it in Europe for 20 years.
Europe tried EGR also on Diesels and FAILED if teh Germans can not make it work right aka MAN Mercedes Benz and Dutez diesels no one can. So the EGR system is going to be the Death bell for EMD they are just to stubborn to see it.
In their own equipment John Deere has gone excluslively with the superior EGR
Cat I asked a simple question at both my Local Case Fealer and my Local John Deere dealership how long the EPA has mandated Emission controls on Farm Equipment I was told that this was the First YEAR that they required reductions in Emissions from it. There is a Huge Farmer that all he has bought is John deere for YEARS farms around 3000 acres between what he owns and rents around here. I am friends with this man and he also OWNS a trucking company. He heard John Deere was going to go with EGR and CASE is not he was due to replace 3 tractors and his Combine NEXT Year guess what he is ordering RED because of John Deere going with EGR.
Rugged looking locomotive. Looking forward to seeing one in HO scale.
Hmmmm, looks just like every diesel locomotive made since 1961, a long square metal box on wheels, how can you possibly tell one from another.
I ask the same question about diesel locomotives built before 1961.
Oh wow, that’s cluttered. My new truck ran horribly bad mileage with EGR and a DPF filter. Got a tuner and ripped that junk out with a quickness. Mileage went up, power went up, and now I can smoke like an Alco.
Adrianspeeder
