First time HO gauge industrial layout advice
Hello everyone i am needing some advice on a layout im building.Curentlly i have built the bench work with a foam top that is shapped into a U shape.One side of the U measures 13ftx3ft the shorter bottom of the U measures 2ftx7ft and the opposite long section of the U measures around 18"x6ft.I dont have a clue which way to go with it as i have never built a train layout before.I have purchased a walthers cement plant and a fuller rock crushing plant that i would like to incorperate into the plan,any advice for track switching and track sections would be greatlly appreciated.
It sounds like most of your railroading is going to be done on the 3 x 13-foot side of the U. The 18" x 6’ side won’t be very useful as another town, since there won’t be enough length for a lot of sidings. What I would do is use a low backdrop to separate the narrow side into two 9" wide halves. Use the back half, hidden behind the divider, for a 4-track staging yard to represent connections to the rest of the world. The front half, visible to operators standing in the middle of the U, can be a branch line, either with a few industries represented by backdrop flats, or a single larger industry (like a paper mill, auto plant, or steel mill) separated from the rest of your layout by a brief stretch of rural scenery to make it seem like a longer run.
Hi Steven thank you for your reply.I have decided to place another section at the open ends of the U to join them together that way i would be able to have a continuous track leading back to the main board,does that sound practical to you Steven?
It depends on the purpose of the layout. If you’re building it because you like to watch trains go around and around in a circle, then yes, build that connection. But if you’re expecting to operate it realistically, with trains traveling point-to-point to deliver cargos, that connection will create a shortcut you’ll have to pretend isn’t there to justify taking your trains the long way around.
Another consideration is, how tall is your layout? If you build this connection, will you be able to comfortably duck under it to get into the central operator’s area? If so… how many more years will you be able to do so? If not… are you confident enough in your layout-building abilities to make this section a working lift-out or swinging gate?
Hi Andy110675,
Sounds like you’ve got a nice blank canvas to work with and in for loads of fun. Steven’s suggestion of partitioning the short leg of the U & incorporating a staging yard is a good one, so too the use of background flat structures. Another good idea would be to take a good gander at John Armstrong’s book, Track Planning for realistic operation, an invaluable aid to layout building imo.
I too am building a U shaped ISL & while sometimes missing the ability to have continuous running it is switching operations that are my cup of tea. My layout’s connection to the outside world is via a static carfloat.
Regards, Peter
Thank you both for your input,i am confident in my building work as i am a coded welder and plater prior to moving into trains i have built numerous scratch build models including 7ft mega yacht,1/4 scale truck a fully functional 1/8th front loader and a 1/9th f-16 turbine but to name a few.The hatches are both removable Steve so that wont be an issue.My ideal layout would be industrial with no passenger trains and no stations fields or houses etc.My main problem is where to start with the track does it have to resemble a real life layout or is it possible to build from your imagination.I will take a photo and post it to give you a better idea
Hi Andy. Welcome. If you’re going to have circular benchwork with a center pit for operating (aka donut), google Heart of Georgia HO scale layout.
You can also search for Big Island Rail and Tom Klimoskis Georgia Northeastern layouts in previous editions of MR and youtube. These two are slitley bigger than your space and have a center penisula that you probably dont have room for, but the articles provide nice ideas.
These are all plans I’m familiar with that offer continuous running and switching. Of course, you can add or delete switching spurs and industries to suit your needs.
Once something is designed by you and posted as a pic, we can offer more specific observations and suggestions.
Also, as Steve suggested, think about theme and what you want to model. It sounds like you’re interested in aggregate/cement. You could build an entire cement complex in the space you have, if you wanted to devote the layout to one industry.
edit: A previous contributor to this forum, Steinjr, also built a small donut Industrial Switching Layout that is close to your space. You might want to try and find his layout via typical search.
I would second HO-Velo’s suggestion to lay your hands on a copy of John Armstrong’s book. No volume is more valuable when it comes to designing a layout that operates like the real thing.
The OP is looking to do something that is practical, not necessarily prototypical. I would suggest that the continuous run idea is practical.
I always struggle with the notion of what is prototypical because it is not always easy to perform prototypical operations on a model railroad, especially one that is smaller than larger.
Space considerations and selective compression always seem to raise their ugly heads.
First thing the OP needs to decide if he wants a continuous run or actually wants an industrial switching line with pretty much all switching. Makes a big difference in the design. If the OP doesn’t need a continuous run then the U shape is fine.
If he is going to build the benchwork before having a track plan, then he can actually design on the benchwork. Buy a switch of the size he is going to use, one of either hand (left and right) and then photocopy them Cut out the photocopies and use them to design the track plan right on the benchwork.
Pick the primary industry or industries he wants. Then sketch out the way he wants the cars to flow. Google the type on industry he wants to model, see what components the industries use. Before everybody gets all bent out of shape about me forcing him to be prototypical (I’m not), researching an industry helps improve the variety of cars. What inputs does a cement plant use? What outputs does it have? He would need limestone to make the cement, probably fly ash as an additive, plus either coal or oil as a fuel. Output would be bulk cement in covered hoppers or bagged cement in boxcars. Where does he want to locate his railroad, what part of the country? That will determine whose covered hoppers are used to load the cement and where the nearest coal fired power plant is will determine whose covered hoppers the fly ash is in.
Picking a location will also determine the scenery (Utah looks different than Pennsylvania than Texas) plus it will also help pick other industries, because he’s going to want more than just a cement plant. I personally like a beverage/beer distributor. That allows a wide variety of boxcars, RBL’s and mechanical reefers to be delivered. If you are in Texas a pipe yard or oil field supply might be in order. If its in Kansas, a feed mill or grain elevator, or a farm implement dealer.
I would als
great advice from you all thank you.I have extended the the U shape so both sides are 13ft the narrow side is 2ft wide and the others are 3ft.I have seen a place on google earth its on cement plant road knoxville Tn united states but im not sure if there are enough lines to keep me interested in this one but take a look and let me know.I have all so removed the loop so it is back to a U shape.
From the previous description and this one, will enclosing the U form a perfect rectangle? From the earlier description and this one, it seems like the shape would be like the small letter b
Hi i have decided to go with the U shape with equel sides i am planning now on following somthing down the line of hanson cement in the uk but using american locos,i dont like the look of uk locos at all lol.
How do i insert a pic as it asks for source and size etc
Andy, that sounds great. Switching layouts can be a lot of fun.
I really think the best way to approach this is to google search trackplans and access the MR data base if you are a subscriber, then pick out several plans that interest you. Offer up those plans for comment to see if you like any of the alterations that the forum will inevitably suggest.
As Steven alluded to, overlapping elements of a track plan can be really helpful in smaller spaces. Staging, runarounds, switching leads, and industry tracks can often each be longer this way than if they are arranged sequentially.
Good luck with your layout.
Please read the pinned thread at the top of the General Discussion (Model Railroader) Forum. How to Post a Photo to the Forums
Check these out on page 44/45 do you think it would be a good choice to incoperate the two designs one either side of my U shapped layout and bridge the two together. www.layoutvision.com/…/bh_small_layouts_2015_slides_download.pdf
Right click thencopy link address then second on the list[:D] i hope
then paste second ond the list
