The Freight car page is divided up into three major sections:
Photos
NYC Freight Car Diagram Book
The photo seem to go by road number so it may have to hunt for it. However, the Diagram book has road number in the drawing. That will at least narrow it down for you.
Hope that helps…
FYI: Cab stands for caboose. So, any of the pictures that start out with “CAB” will be ones of cabooses. (They were normally #'d 17,000-21,000+.)
As for the NYC’s 40 foot (nominally) flat cars, according to the 1944 freight car diagram book, they had five genral classes of cars:
Class F-1, 30’ 1-1/2" long, built 1905: P&LE 6883-6884
Class F-3, 42’ long, built 1910: PMCK&Y 13450-13499
Class F-13, 41’ 1-3/4" long, built 1910-1916: NYC 495293-495692, B&A 16000-16399, NYC 498000-498499, MC 32750-32899, MC 32700-32749
Class F-17, 42’ long, built 1923: NYC 498500-498999
Class F-25, 42’ 10-1/2" long, built 1930: NYC 496000-496299
That’s 2352 cars in 1944, a healthy number (considering eastern roads generally had small flat car fleets). But by 1950, the roster was down to only 595 flats (out of 1796 cars) under 50 feet long, being supplantented by 52’-58’ cars.
Can you take a 12 MEG email? I’ll gladly SHOW you the NYC’s class numbers, straight off their 1944 diagram book. The NYC used BOTH class numbers and lots. If you’ve ever paid attention to the lots, they represent a single car order, irregardless of car type. You can have a dozen or more orders of the same, exact car, but with hugely different lot numbers. Most NYC fans refer to the lot numners, since no one’s taken the time to cross reference every lot to its corresponding class diagram.
When in doubt, refer to the source material, not memory.
Are you sure those are class numbers and not just page numbers? If you look at the index (and in some car tables), the tables refer to F-25, B-14, and the like as “page numbers”. Also, there seem to be a lot more “class numbers” than car types. For example, the diagram of the car you call “F-25” is on page F-25 while the production data is on page F-26. If that notation at the corner of the diagram page was the car class, what does the notation F-26 on the next page represent?
Whoa! Before you two go shooting off at the mouth again, why don’t you cut Ray some slack. First off, he’s a very knowledgeable modeler and knows quite a bit about RRing - especially about the NYC. You guys are blowing steam like he’s some sort of idiot.
Secondly, there’s a way to disagree with someone without being disagreeable! You should feel free to question someone’s sources. But try being a little more tactful about it next time…
Tom, that’s not fair to me at all. Here’s what I wrote:
“Are you sure those are class numbers and not just page numbers? If you look at the index (and in some car tables), the tables refer to F-25, B-14, and the like as “page numbers”. Also, there seem to be a lot more “class numbers” than car types. For example, the diagram of the car you call “F-25” is on page F-25 while the production data is on page F-26. If that notation at the corner of the diagram page was the car class, what does the notation F-26 on the next page represent?”
How does this come under the category of “shooting off at the mouth?” What did I say that was being disagreeable? How does this make Ray sound like an idiot?
Perhaps you should try just reading the words I wrote rather than assuming I must be accusing or insulting.
Forgive me. [:(] You are absolutely correct. I was looking more at Eric’s initial post and then mistakingly lumping you both together. After re-reading your post, you did respond in the right way. I, on the other hand, didn’t do as well, did I? [:I] I guess I was rather quick to come to the defense of Ray - NOT that he isn’t capable of defending himself well enough.
Again, Kurt, please forgive me for my rather terse and inaccurate accusation about you. I was wrong and I am sorry.
I’ll grant you that your first response, in and of itself, only questioned Ray’s sources. I guess it was the above response to Kurt’s post to Ray that lead me to believe otherwise: “…who can read for comprehension ;-)” implies that the other person in comparison (in this case, Ray) either has none or has trouble with it. That’s the statement that bothered me. Sorry, Eric, perhaps the use of the term “idiot” was a bit over board on my account.
OK, I need to apologise: NYC Fan’s right: what I thought were class numbers are actually page numbers. There’s no good explanation in the 1944 or 1950 diagram books, but I found this in the 1924 book:
“Car diagrams and tabulations are paged in accordance with the following system. The letter refers to the initial type of car. For example, “B” refers to Box Cars, “H” to Hopper Cars, etc.; the odd numerals referring to diagrams, and the even numerals to the corresponding data sheets. For example, “G-3” refers to Wood Drop Bottom Gondola Cars, and “G-4” refers to the data sheet corresponding.”
So I was wrong about the NYC having car classes: they didn’t. I think I was biased by all the other roads I look at on a regular basis which DO have car classes. While other roads only used car series numbers, the NYC has what I think is a unique system in their lot number series, which is actually VERY confusing, since different lots refer to the same exact cars. And on the diagram sheets, all of those lot numbers ARE lumped together into the same drawings.
