Flickering DZ1000 Lights
Last night I was running trains and things seemed pretty normal. After a while though the LED’s on the DZ1000 push buttons on the control panel started flickering whenever a train passed over the isolated section of track that serves the de-rail function. You could actually follow a train around the layout (which is not that large) just by watching the flickering lights on the control panel. I manually cycled the turnout controls using the pushbuttons with no effect. It was late so I had to shut things down but I did check for any obvious loose wires or connections. The two things I did differently last night was to add one old car and to operate at a pretty brisk speed. Removing the car and reducing speed still left the lights flickering. Anyone see something like this before? Could dirty track be causing this? I had cleaned the outer loop which was pretty dirty but the inner loop with the tunouts has not been cleaned yet. Thanks for any insight here.
Jim
If you don’t find a cause send Z-Stuff an e-mail. I’ve always found Dennis most helpful in trouble shooting a problem.
