Flooring for HO Models houses
Looking for idea’s for flooring to put in a model house, what i want is clip art or something simular so that i can print a sheet off and tack it down.
On line flooring company sample pictures. This is also a good source for wall coverings.
I don’t know if there’s anything here that can help you, but it can’t hurt to look.
http://home.wanadoo.nl/schatborn/index2.html
Here’s a couple ideas off the top of my head.
A checkerboard tile floor which could easily be created with any graphics program. For interest, you could turn it 45 degrees.
If you have a scanner, oriental rugs are often pictured in catalogs hanging straight down so you could scan it, shrink it to size and lay it on your floor. If you don’t have a scanner, you might find one in an online catalog that can be copied to a jpg or similar file.
Easy! Get the Sunday paper & look for color carpeting/flooring ads in the inserts! Cut them out & you are set![8D]
