Foam with Hot Glue Gun
I am trying to secure some Woodland Scenics foam to my layout. I have a low temp hot glue gun, but it isn’t from Woodland Scenics. Would it be fine for me to use that instead of buying a new hot glue gun?
I’d give it a try. The worst that can happen is that you’ll melt right through that first piece, right?
[:O]
Seriously, I suspect that WS low temp is probably the same as generic low temp, so you shouldn’t have a problem.
I use mine all the time for that. I’ll use white glue as the main holding medium and use the hot glue to tack everything down. The problem with traditional glues is there is so little air movement that it takes forever to dry. By using any low temp hot glue it will hold it in place until the regular glue dries.
I use regular glue as the main glue instead of all hot glue as gluing sheets and sheets of foam down and in place would be too expensive
ratled
It should work just fine. I have a Craftsman glue gun, which is not particularly low temp – just apply it from a little further away and give it a chance to cool a bit before it hits the foam.
If you’re using regular glues, apply them in an “S” pattern so that no part of your glue bead is fully enclosed by another – otherwise that inside bead of glue will never cure.
After you get done, if there aqre those thread like streams of glue, use a hair dryer on hot, just enought to make them the threads disapear. Wont hurt the foam at all
For large pieces of foam, I think you would find it more cost effective to use acrylic latex caulk. It holds the foam securely, and doesn’t attack/melt the foam. It DOES take longer to set up ( I usually wait 24 hours before proceeding).
