Hi, after i was done laying the track, stupid me relized that i had forgoten to insulate the sidings.Is there anyway i can do this after i have installed the track? it’s allready all glued down and ballested on cork roadbed. any help would be great thank-you Bear.
If you have a Dremel tool, you can put in the cut-off disc and cut your rail. Then glue a piece of styrene in the gap. I’ve used styrene that is bigger than the rail, and then I file it down to the rail’s profile. You can then paint it to match your track. You won’t even see it.
Scott
Thanks tried it work’s great!! all i have to do know is fix em all and paint.
