Form B question
nhs792 – a Form B with a limit of 4PM holds until 5PM. Flags left by a 4man set for a Form B cause the restriction to remain in effect. A 4man can take the railroad home in his pocket and absolutely close the railroad down if he had a valid Form B in effect and the flags out. I have seen this happen several times. Form B’s are there to prevent trains from running over track crews, and such, they absolutely inviolate.
Ed — Glad to see all is working better. Music sounds so much better when all of the instruments play from the same sheet of music. Railroads run better for the same reason - but then we both know that!
Problem here now is not staying Frosty, we have plenty of that at the moment. But I’m sure you could use some of it, but Uncle Pete won’t be able to get it to you fast enough to do you any good!!
Stay Frosty - me? I’ll try to stay warm, thank you.
