i just tried to download Atlas RTS 7.0 track planner and could not get it to run, something about language files not matching up, and need to reinstall it, did that three times, and thats my lucky number anymore than that and its not worth it to me.
What i would like to know is if there is another program out there that is free and does basically the same as the RTS, or if it is known what the problem is maybe i can fix it
There’s this http://www.sillub.com/. It’s called xtrkcad. I’ve not used it but some guys here (which is where I got the link from) say it’s pretty good.
I’m a big XtrkCad fan. I found it more useful that thr Atlas system. It does require some learning time… there is a tutorial with it that is a must. Once you “get it” it becomes a sub-hobby of its own. Try it!
This has the latest version of the program plus alot of experienced people that can help you learn the program. I HIGHLY recomend using the animated tutorials they will show you how to get the job done and leave you able to work with little questions. I have used this program to design my last 2 layouts and both have worked great.
I have used it before and like it, as well. It is now an open source project and you can get the most recent versions and information at the XTrkCAD Wiki.
