Freight car ordering?
I know the car order matters for a passenger train. Is there a similar ordering on freight trains? Do reefers come before boxcars, or tankers after flat cars?
Thanks.
Typically no. There are trains where blocks of primarily one type of car are placed together (and may frequently appear in the same place when that particular train runs), but not due to any set rule about where cars go by type as with a passenger consist. Certain cars (e.g. loaded tank cars placarded as hazardous, boxcar loads of explosives) must usually be spaced away from occupied locomotives or cabooses, but again that’s not a passenger-style arrangement.
Freight trains that stop at different yards block all of their cars for the various yarsd so that they can be quickly dropped off and if their is a block of cars to be moved to another yard furthur up the line, it will be placed on the train. The types of cars in block do not matter. The only rule on the placement of cars are for those carrying hazardous materials.
I believe I remember different rules on a consist like “do not hump” or “not to be placed near xxx” type railcar. Then again I sat in an office all day.
There are rules such as hazmat cars must not be placed next to a occupied car or locomotive other then that trains are made up into destination blocks from front to rear…
Here’s more information…
Enjoy!
http://www.sdrm.org/faqs/rulebook/toc.html
When livestock was shipped by rail, loaded stock cars were to be marshalled next to the locomotive. This was to reduce the effect of coupler slack and run-in on the livestock. Any injury claims were the responsibility of the railways.
When empty, the stock cars were treated as any other car.
With some exceptions (like loaded stock cars mentioned above) car type does not matter.
Freight train handling is all about blocks, not individual car ordering. A block is a bunch of cars to be handled together, usually by destination (or, the next major yard it needs to be handled at on route to its destination). The ordering of cars within the block is not important (as long as hazmat placement rules are observed).
Blocks are defined by the operating department to support efficient operation. For example, a train that runs from A to D, with stops at B and C will likely handle blocks for B, C and D. Anything beyond D will be mixed into the D block, and resorted at D. Let’s say that at C there are a couple of connecting lines or branches. This could connect to towns E,F,G,H,etc., but rather than having individual blocks for all those locations, the mainline train will just have it all mixed in a block for C. At C, the cars will be sorted for their next destination(s). And that’s how car routing and classification works. Each yard has a specific set of blocks that gets made up there. A car in Detroit bound for Los Angeles wouldn’t go in an LA block, since there’s no train to there. It’d probably go in a Chicago block and get re-forwarded there.
In some cases, perishables will have their own block, so they’re handled in a high priority train, or blocked together for servicing (icing or refueling depending on era/type of car).
There’s an excellent discussion of freight blocking in John Armstrong’s Track Planning for Realistic Operation . This book also contains a lot of other information on real-life railroad operations that’s very useful to modelers.
Depending on railroad, there can be certain other train make-up rules besides those for hazardous materials.
Some examples are restrictions on Long (80 ft or longer) car/Short (45ft or less) combinations. Load/empty placement. Certain train placement locations for dimensional or high value loads, etc.
Some of these restrictions may depend on total trailing tonnage for a train. What would be a placement error for 7500 ton train might not be for a 3500 ton train.
Jeff
Yes and no.
It is more by commodity than by car type.
As previously mentioned, placarded loads of hazmat, particularly tank cars cannot be within 5 cars of an engine or caboose, plus some hazardous loads can’t be next to other hazmat loads (e.g. you can’t put a car of explosives next to a car of flamable gas.) Typically livestock was near the head end.
There are some rules on some roads where short cars (beer can tank car) can’t be coupled to long cars (89 ft flatcar) and where you can’t put blocks of empties ahead of blocks of loads or a certain tonnage.
The most common ordering of a train is by “block”. A block is a group of cars that will be handled together. They will all be going to the same destination, the same interchange or the same yard to be switched. Those blocks will be arranged in the same order in the same trains day after day. So if a certain block tends to carry specific cars, then the train may appear to be blocked by car type. I once told a switch crew to switch a track by car color, red, grey and black. The red cars were all hoppers and gons going back to a mining area, the grey cars were all plastic pellet covered hoppers going to storage and the black cars were all tank cars going to an area with a lot of refineries.
Way freights or “peddlers” that set out and picked up cars often are set up so the first car (or cars) behind the engine would be the first one to be dropped off, the second car is the second one to be dropped off, etc.
There can be exceptions of course, sometimes an engine couldn’t go say into a building to pick up and set out cars, so that car might be the last freight car in the train, so the train could serve as a “handle” to reach in and drop it off inside the building.
As others have noted, there is no rule, but I have noticed sometimes there were specific orders of freight cars for certain trains. I have followed the D&RGW, mainly for the 1980’s and I have noticed that there were hot shot TOFC trains which would block certain freight at the front, like the Coors beer PC&F 61’ RBL’s were blocked at the front and the TOFC behind. I’ve seen blocks of cement hoppers at the front too, so there sometimes are an order or placement of blocks as others have commented.
Most of the locals I was familiar with were blocked with the cars for each location (station) in no particular order. The blocks in the train were usually in no particular order.
In the case of a handle, if there weren’t enough suitable cars on the train to use as a handle the yardmaster would have to add some extra cars (usually empties) if the restricted track was going to get shifted that day.
Also, the YM would have to make sure the local could properly space dangerous cars, even if he had to add spacer cars to the train.
There was a discussion a few years ago about the placement of livestock cars: http://cs.trains.com/mrr/f/13/p/130904/1471909.aspx#1471909
Thanks for all the replies! This will help me organize my freight setup.
This has been a very interesting discussion.
In today’s world of long trains, one concern is lots of empty cars up front and loaded cars in the back. Can stringline on sharp curves. Norfolk Southern particularly learned not to have many empty center-beam flats up front when ascending Horseshoe Curve. Two messy derailments.
Roger Thomas
Roger,Both NS and CSX still runs empty racks up front…
Its my understanding DPUs end stringlining because there’s less stress on the lead cars.
I was watching the Fostoria railcams and notice several CSX trains had DPUs about midtrain.
DPU’s change the train make up, the positions of blocks of empties next to blocks of loads has to be looked at wherever there is a locomotive. The special instructions for the Western roads have a several pages of instructions on where to place DPU’s in the train and what the train makeup should look like.
This can vary by era and location.
I believe the FRA requires spacer cars, so you see specific buffer cars on unit oil/ethanol/etc. trains, but Canadian rules have qualifications like “where train length permits” and “unless the entire train is made up of [said hazmats]”, so adding spacers just to be spacers isn’t required if the whole train is placarded tanks. Unit oil trains run without buffers here unless the equipment ran through from a US origin.
Also remember that tank cars aren’t necessarily dangerous - lots of non-hazardous liquid commodities like vegetable oil, tallow, corn syrup, etc. are shipped by rail.
