Well, I thank all of you for your advice and your sympathy. Before I started this grand adventure, I’d already ordered another supply, this time from All Electronics. So, I had a backup to put in once I figured out what was wrong.
As I suspected, I had a dead short. In all my crawling around over the last few months to add new wiring for Phase 2 of the layout, I knocked some wires loose, and put them back together, well, together. Not good, but fortunately easy to find and correct, the right way this time, with solder and electrical tape rather than crudely twisting them together and saying, “I’ll solder that next time I’ve got the iron out.”
The new supply is 4 Amps at 12VDC. I wanted slightly smaller fuses, but all Radio $hack had was 4 amps, so I got those. Once I’d wired in the fuse holder, I slowly brought up the load, which is separated into a half-dozen different sub-buses, each with its own toggle. As it turns out, I am drawing just under 3 amps, so the next supply I buy will be 5 amps to give me a bit mroe headroom.
So, the short took out a 4.5 amp supply, but what happened to the previous one? I took a look at it. This noble wart was rated at 1500 ma, so it ran for months at close to twice its rating. No wonder it finally gave up.
I now have this circuit fused, and I know about how much each of the sub-buses on the circuit draws. I’ve also learned that, unlike old train transformers, there are no circuit breakers in wall warts, and dead is dead forever.
