Well here it is folks, as promised. It needs some work, but this is all I had time for this year. Next year there will be some padding under the track to reduce noise, fallen snow, some vehicles (could not find them in my 20+ bins of train stuff before the pics were taken), and the ‘boxed’ mountain will look more like a mountain.
Layout in place and ready.
Detail of village area
Testing the village Lights
Close up of light holder - these things are awesome!
Double Cross-over
Command Center Area
Close up of the Command Center
The boxed mountain in place, tree up and ready for some decorations
Test run #1
The village gets an unexpected visitor
Tigger is checking out the ice skaters
Still can’t figure out how those little people are moving around!
Thanks! I was very pleased that I got as much into a 64" x 96" layout.
The crossovers took a lot of effort to figure out… the O-36 turnout does not work for a 45 or 22.5 degree crossover because they are 3/4 curves! Why couldn’t Lionel make them 1/2 curves? Then a 45 would have worked perfectly… the switches required modification so the two loops would be independant (you have to remove both pins from the switch)… they really need to come out with fibre pins so the track alignment does not get screwed up.
My personal favorite pic is the last one… I wanted so badly to curl up under the tree with her and take a nap! LOL!!!
Lastnight when I put the passenger loop under the tree my wife walks into the living room and says:
“FOUR tracks?!?!? FOUR? We need to talk!”
My response, “Yes, FOUR. It is one more than 3 and 1 less than five. Three looked rather bland and I couldn’t fit a fifth track into the plan. Now when we have the family over at christmas there will be lots for people to watch!” Gave her a hug and kiss and went to bed! [:-^]
Looks really great! I dunno about your cat, but our two are just TOO dang curious. I ended up buying a “cat repellant” to spray around the board to keep the curiosity to a minimum. Works really good.
LOL! Tigger just likes to sleep on the fleece tree skirt. Once the trains start-up she is goners! Now Panther, the 20lb black cat… he’s another story… he loves to sit and watch the trains go by, he’s my son right now! If I could just get him to wear an engineer’s cap we would be all set!
… and yes I would make him wear the hat if I could get it on his head! [}:)]
LOL…I bought a Christmas collar for my wife’s cat. It’s red and has a candy cane embroidered on it. I never realized a cat’s head could contort to the point of being able to grab something around it’s neck, but HIS does!!!
Very nice work! Love that command center - gives me ideas for next Xmas.
What did you build your layout on - is that foam with a wood base? And is your “mountain” free standing (ie, the weight is on the floor/carpet) or does it rest on your layout base?
DJ,
Thanks. The layout is 1/4 ply over 1 x 3s. The mountain can be moved it rests on the floor as well as on the base (very poor design). The mountain was an afterthought when I realized the tree sitting on the base hung too low for the trains to pass underneath - plus the tree is only 6.5’ so that ment I could raise it up a bit.
Next year I think I’m going to do it a bit different… not exactly sure how, but the outter loop is going to go up under the tree and back down, the inner loop will come up to the upper level, as will the village… not sure how it will look, but we’ll have to see… I would like to keep 3 trains and a trolley…
Also will probably go foam next year as well… this all depends on if we are in a new house or not… so only time will tell… 8 months to think about it! [:-^] Plus I want to get some animated accessories included as well.
DJ,
Forgot to mention something about the Command Center…
Notice it is a ZW… but it is a NEW ZW and the 180w powerhouses are tucked away under the ZW’s based. The little ‘shelf’ behind the ZW goes right over the terminals. And all wires are hidden…
This was based on a larger version a friend of mine built for his christmas layout. The area where the two locos are sitting is where the new CW-80 is going to sit when it arrives later this week. I’ll post completed pictures as well as blueprints once the CW-80 is here and in place.
The shelf also serves as a resting spot for smoke fluid, track cleaner, a couple small screw drivers, and other miscellaneous items. I wanted to move the operating track controller to the command center, but I forgot about it! There is room for, so I am not worried about adding it next year, and there is room for a couple more animated accessory switches too. There are three right now, one controls the ice rink and the other two control the burning switch tower that didn’t make it onto the final layout, but will be back next year as well.
The layout is 100% mobile. The wires can be disconnected from the layout to the command center, and from each other using wire connectors (male - female type).
Next year the passenger station will be inside the passenger train loop also… things you think of AFTER you have it built! [banghead]
I like your layout and the command center is very smartly done. Your layout is very similar to mine in many ways. I was able to sneak my ZW and the controls in at one end of the layout but did scarifice a little track space to do so. Hmmm, maybe I will reconsider for next season after seeing how you did yours.
My layout is a 4’ x 12’ with two independent loops with one short spur. The main similarity is I also have a platform built up for the tree to stand like you do. While the trains are running underneath there is room for presents around the tree and after Christmas morning another quick loop of track is added for the last week or so of fun! I cut three viewing portals in the side of my platform so the trains can be viewed as they circle under and around the tree.
Nice work and thanks for sharing the views of your Christmas project!
Hello Lionroar- That is a sharp christmas layout you’ve got there. Lots of detail & action also. Too bad it is not a permanent layout. You put lots of thought into it also. Take Care.
Thanks RRR and Keith,
I tend to jump into projects and modify them as I go along. The christmas layout, as stated before, is always going to be a work inprogress. I am planning such a large layout that I need a way to try things out beforehand, it is easier to try it small and work out the kinks than it is to start large and have to scrap something that could cost a bunch of money.
Having read the posts in the forum for a week now, I have gained quite a bit of knowledge and the layout will definitely be totally different next year.
I have a few new ideas on how to build the layout and will be posting the results of different tests, including sound files.
This layout is incredibly loud. I had both mainlines, the trolley line and the passenger loop running last night and you almost couldn’t sit in the living room! So it has to change.
I am toying with the idea of incorporating three concepts for subroadbed material into one:
Put 2 inch foam over 1/4 inch plywood (the plywood would give a nice firm base, attached with construction adheasive.
Cut ceiling tile (from Franks posts) to about 1 inch wider than the FasTrack roadbed and adhear that to the top of the 2 inch foam.
Cut carpert padding so it fits snuggly inside the underside of the FasTrack roadbed.
Attach the insultated FasTrack to the ceiling tile using #4 screws.
The reason for this is I suspect the open air under the FasTrack roadbed is acting as an amplifier for the sound, by installing the carpet padding under the roadbed that should deaden the sound. The ceiling tile is lighter weigth than ply and provides the grip for the screws. I can then ‘sculpt’ the foam and use it as the support structure for the scenery… those furnace filter pine trees can stick right in to the foam too! I can also make the ‘mountain’ lighter by layering 2 inch foam and cutting the tunnel path into the foam, then attach ceil
I like your layout and the detail on what you did, especially about the sound deadening. your control center looks neat. My train does make a bit of noise. My track is not permanently installed, just sets on the surface. I may have to try the carpet under my MTH track for my layout under the tree. Its just an oval (54" diameter) on 2 layers of 2 inch insulation foam, painted white. 4 ceramic type buildings with lights. Pretty simple but it adds so much to the tree. Thanks for the photos.
Mickey,
I haven’t done the foam, ceiling tile, carpet foam bit yet. Those are ideas I have gotten from others on the forums, and combining them after doing some reseach on acustic deadening.
I’ll keep everyone up-to-date on the progress and what I find during testing.
