From the Only Dumb Question is the One Not Asked Department
I want to use DPDT switch to be able to spin my turntable in both clockwise and counter-clockwise directions. Assuming I’m using Red and Green wires, is this the way it should be wired on the six poles?
R-R-G
G-G-R
You got it!
Use a momentary-center off-momentery if your not using a seperate run switch.
Mel
My Model Railroad
Bakersfield, California
This is easier than the way I was going to do it.
I doubt the switch I have is momentary. So you are saying I use this to control direction, but I need another switch to run the motor.
there are 3-position DPDT center off switches.
Spacemouse, you will want to use a momuntary switch (as mentioned above by RR_Mel) to run the turntable CW and CCW (returns to center off by it’s self) Sorta like a deadmans pedel, so if you fall off your seat, the turntable will stop moving. You just release the pressure on the lever and it returns to center off.
Eliminate the two switch (one for direction DPDT and one for movement, momuntary) setup and just use one switch, DPDT center off ,momuntary.
Yeah, I know you’re right. I worked this out before I read the forum this morning. And now, when I think about it, the turntable on club layout I belonged to in PA had a MOM.
Done. On it’s way from East eBay. Only a week’s delay. Sigh. I need to get the rough wiring done so I can button down the plywood and lay some track. I wanna hear some chugga-chugga choo-choo.
I built up my own indexer to auto select the tracks but I also have manual control using two switches as shown in the drawing below.
If the motor in your turntable coasts after removing power I have a fix for that too.
Mel
My Model Railroad
I guess we ought to know just what turntable is involved here. If it’s an Atlas, with its geneva mechanism, no need for a momentary switch, the indexing is fixed and mechanical. If it’s a free-spinning turntable like one of the Walthers kit ones with the motor added, then a momentary switch is kind of needed to jog the table into final alignment if there’s no indexing.
That’s a good point about controllability. I have an Atlas, but I “pit-bashed” it so the alignment is not as perfect as it would have been if I’d just left it as a deck turntable. (But what fun would that have been?)
I do have to jog the turntable to get proper alignment for some of the stall tracks. My control toggle is a simple DPDT center-off, and I’m able to align it without any trouble. The Atlas drive is slow enough and I run it at reduced voltage.
