Back in the pre-Amtrak days when the NYC was running the 20th Century ltd, and the PRR was running the Broadway, would these trains require refueling in transit, or could they make the entire trip on the original set up?
The engines may have carried enough fuel for the 960 or so miles. I do not know of engine changes on the South Wind, but the City of Miami engines ran between Chicago and Jacksonville, taking fuel in Columbus, Georgia (840 miles out from Chicago; the 1128 miles to Jacksonville probably was a bit too far). The engines on the Seminole were turned in Columbus.
Doubtful. The best engine NYC would have used would be an E8, with 1200gal tankage and a nominal rate of around 188gal/hr for the two 12-567s (remember the sfc goes way up for a blower engine, which all of these were, by run 8 where one might expect much of the running would be made).
To my knowledge this does not count the steam generators, which were nominal 1200#/hr, probably about 6:1 on fuel and fuel at just over 7#/gal; you can do the math required.
The only steam engine that might have been able to make the trip without a fuel stop would have been the C1a with 64T tender – and even then, there’d be very little reserve if conditions were off ‘perfect’.
In that case, would they have been more likely to make a fuel stop, or change out the engines entirely at some point along the way?
I’d expect refueling, with fairly large hoses and high-gph pumps, in less time than it would take to uncouple with steam lines and replace the consist. Note that ATSF routinely serviced their diesels with fuel, water (for steam, and they used more of it than most with steam-ejector AC for the cars), and lube oil within about 5 minutes, and I would expect NYC to use comparable efficiency.
It might be interesting to see if any ‘lesser’ NYC trains that ran through Cleveland with mandatory power change could do the ‘diesel legs’ east and west without refueling. That doesn’t apply to the Century.
Someone here will know how many times the Century would be recrewed, and where. Those are the places I would expect the high-speed fueling and watering to be provided.
Long haul passenger trains had to be both fueled and watered - watered more frequently than fueled.
The B&O watered EB trains from Chicago at Garrett - the East End of the passenger platform were equipped with equipment to water 3 units during the normal station stop and crew change. When they operated their F3’s on passenger trains from Chicago, they were frequently out of water on their arrival at Garrett. The regular ‘E’ units had no trouble in making Garrett for water. The trip from Chicago to Garret included a significant amout of ‘terminal’ steam generator use - moving the train from Robey Steet Coach Yard to Grand Central Station and the waiting during the boarding processes - which could be delayed for connections from Western operators - so the steam generators could be operating for a extended period of time.
The nominal fuel consumption for 1st generation diesels was considered to be 2 gallons to the mile. I believe, on the Baltimoe-Chicago run engines were fuled during the station stop/crew changes at Willard and Cumberland. While you never want any train to run out of fuel - it is especially bad press for it to happen to a passenger train.
Presuming that a location is configured for fueling on the Main Track - it is much faster to fuel engines than it is to change locomotives.
Amtrak fuels Auto Train (and I believe all the Silver Service trains) at Florence, SC.
Remember the first 33 miles of the NYC, and 200 miles of he PRR were electric.
So then assuming they had infrastructure in place that allowed on-line refueling, would the locations for these be likely to show up in the schedules? For example an atypically long station stop. Keeping in mind they were trying to keep overall transit time to a minimum. I think 16 hours at one point?
Balt: Think that Florence would need a very ----------- long ----------- hose to fuel the STAR !
All the ones that actually operate through Florence.
Yes, it is about sixty-five or so airline miles from Florence to Columbia. Camden is a bit closer, but the stop there is brief; Hamlet is little closer, but not a whole lot.[:D]
My experience with Amtrak fuel stops has been that they are accomplished within 10 to 15 minutes at a slightly extended scheduled stop.
The northbound City of New Orleans is routinely fueled ( by contractor using a 10-wheel tank truck). I will have to repeat observations to get the number of actual gallons per unit and the pumping rate (both of which I can get off the LED fuel gauges on the Genesis locomotives without involving the truck crew). When there are multiple units the single hose is transferred sequentially. I have observed no particular boarding restriction on passengers leaving the station adjacent to where the truck pulls up – this might have been different in an era that permitted smoking in stations.
ATSF E1’s being fueled - back in the day!
What AT&SF station is that?
I’d hazard a guess…Albuquerque (?) Curtrently, AMTRAK SWC #4 gets fueled there… The track to the left in the photo with the tankers, and spotted passenger car, is now gone.
The terminal has been remodeled, and that track and its area are used for passenger traffic off the platform and into the station.
The current through track [with the passener train on it; shown in the OP’s photo] is to the right of the renmodeled passenger/baggage handling area.
Refueling is accomplished with a 10 wheeled tanker truck, driven onto the platform to accomplish the refueling. Similarly, SWC #3 is refueled there as well.
Kinda interesting is the Newton Ks station. BNSF has a diesel fueling stand with storage tank to the west, across Main Street from the station.
In the photo, look how many guys it’s taking to fuel the engine compared to dealing with laundry on the other side of the engine.
Outstanding picture, btw.
There are fuel tanks on both sides of the locomotives? Correct?
So then is there some type of internal equalizer allowing fuel to cross over from one side to the other?
Locomotives have one fuel tank with fills on either side. They each have a water tank for the steam generators with fills on either side. In the day, locomotives had to be watered more frequently than they were fueled, they would generally be watered at the same time they were being fueled.
Today’s passenger locomotives no longer have steam generators and don’t require water of heating/cooling purposes through the train. The use Head End Power (electrical) to power the heating/cooling through the train.
The Sunset Limited refuels at the fuel yard to the east of the San Antonio, its not a pax stop. Is there another Amtrak train that does the same?
