Furom Bug- Delay in type
There is a bug that when I type the letters dont always appear right away whats going in here…
Others have had this problem. See
http://cs.trains.com/trn/f/111/t/250926.aspx
I have had a similar thing happen since then when sending an email, so it may not be the TRAINS forum’s fault. If I “X” out and re-enter the program, it is usually OK.
You also seem to have a bug which makes you misspell forum.
You are being moderated by the moderators. They’re on to you. [;)]
Computer software is lagging behind trying to keep up with which user name he is using this week.
Keystroke virus stealing your brain through the keyboard
fun with words todayand change a tire in the slushy snow.Lots of fun in the mountains .
Try rebooting your computer and see if that helps. Some browser plug-ins are notorious for memory leaks, and when enough memory become commited to supporting zombie processes, it forces your computer to start using the swapper functionality, which can cause exactly the problem you mention.\
Check the hard drive light on your computer when this is happening. Is the light showing constant hard drive activity for no apparent reason?
When i have that problem, rebooting always seems to fix it.
A mispelling? That’s unpossible!
