G-Scale Help
I am in the Chicago area and need some help. What is the trick to keeping trains running in the snow and when it gets below freezing, I assume that there is something that can be put on the rail (whal clipper oil?) that repels water so that it does not freeze on the rails. I set up a circle of track for the holidays so battery power is not an option, I am using small 4 axle LGB diesel and steam locos, any help is appreciated I just got done crawling around on my knees in the snow cleaning track with a drywall sponge for about an hour to no avail.
Post this on the Garden Railways forum. You will get more replys there. I hang out there a lot to because of my own GRR.
Hi cttrr
Apart from posting this in the garden railway forums where you will get better results.
Literaly Get an Arristocraft snow plow put a a house brick in it adjust the blade and shove it around with a heavy powerfull locomotive.
regards John
