gallium vs. lead
Actually there is one contender: lead-bismuth eutectic (which is slightly heavier than lead and melts at a reasonably low temperature for ‘home’ casting but above attic or ‘in the sun’ storage…
This is one of the sensible nuclear coolants, like NaK without the reactivity… if you overlook that l’il business about polonium-210.
I still dimly remember books from the '50s that advocated Cerro-Bend (melts in boiling water!) and Woods metal from sprinkler activation for homemade weights…
For the sake of one more whack at the equine: the use of gallium anywhere in weights would be solely as an alloying agent with lead to decrease melting point. Let me stick all the nerd stuff in a reference link that only the interested would need to peruse.
https://link.springer.com/article/10.1007/BF02663678
You can get 5 pounds of lead for the price of one pound of Cerrobend. And it’s 25% heavier.
I would reserve it for special purposes, like filling an irregular void. Speaking of which, compared to lead shot, it has no voids. That can wipe out lead’s higher density.
Ed
I’ll stick with lead, everything else here seems complicated and costly for me.
Maybe 25 years ago I made the mistake of saying at a supply house, "I’ll take a piece of the sheet lead, cut me a’’ (I do not remember the exact size I asked for) but let’s say it was maybe 4’ x 6’ maybe 8’. I bearly could lift it on to the truck let alone get it up to the second floor of the shop. This is the only piece of lead I bought besides 2 or 3 pre-package what 1’’ x 12’’ strips which IIRC had painted ends (yellow or green) to identify the thickness. Well I did buy a gallon can of Fishing sinkers at an Auction cheap because nobody wanted them.
No lie, right now I have close to 2000+ lbs of lead in sheets, ingots, window weights and CI pipe joints. Wayback when the scrap yard was giving .08 a lb. I figured it was not worth it to take in, so I stock piled it.
The below picture shows Bowser caboose floor weights and Stewart slope sheets cut and punched, ready to install.
I used the supplied steel slope sheet weights on my Stewart U-channel hoppers, but used a utility knife to cut sheet lead into ones that fit atop the slope sheets and into the hopper bays.
The regular Stewart hoppers, when empty, are rather light, so the extra weight helps to keep them tracking well. Loaded, each car tips the scales at 9oz.
Well you can’t go to your local bait and tackle shop and buy depleted uranium fishing weights either, so I guess by your logic lead is more dense than depleted uranium.
[bow]
A few years ago there was internet rumors (lies) that sheet lead was going to be “outlawed”, so I bought a lifetime supply.
Your stash however, puts mine to shame, and I never stamped any specialized shapes.
Great work!
-Kevin
If gallium is liquid at fairly low temperatures I wonder if it could be used to represent molten steel filling a mold or slag being dumped from a slag car.
Getting the right color might be difficult.
I mentioned earlier in this topic that gallium melts around 86F. So I guess it depends on what temperature you keep your layout at.
I also mentioned in an earlier post the possibility of using mercury, which melts at -40F. So it’s liquid at all normal room termperatures, and would be a better choice. I see you can get it from Amazon.
Ed
One assumes this is firmly tongue in cheek. Mercury is basically highly poisonous and deserves the highest level of respect if you have to make use of it.
I thought we were in the business of simulating reality here…
Just looked, you can buy gallium on Amazon. $575 for a kilogram
I thought by now everyone knew that you could only coat mercury on a copper penny one time, in your entire life–the second time, you die a horrible death. And the third time is even worse.
Here is a presentation concerning mercury:
https://app.croneri.co.uk/feature-articles/mercury-and-its-compounds-safe-handling-and-dealing-spillages#:~:text=Avoid%20inhaling%20mercury%20vapor%20and%20use%20suitable%20gloves,data%20sheet%20(MSDS)%20for%20mercury%20before%20using%20it[.](https://app.croneri.co.uk/feature-articles/mercury-and-its-compounds-safe-handling-and-dealing-spillages#:~:text=Avoid%20inhaling%20mercury%20vapor%20and%20use%20suitable%20gloves,data%20sheet%20(MSDS)%20for%20mercury%20before%20using%20it.)
Summing up: Do not heat up your mercury. Do not ingest your mercury. Do not spill/lose track of your mercury. When you’re tired of playing with it, dispose of it properly (look it up).
Ed
As opposed to acidically highly poisonous? [:-^]
The dangerous forms of mercury are the ones that are bioavailable – not the metallic element in liquid phase. Ethyl- and methylmercury are particularly ghastly in that respect: in fact more dangerous than the depleted uranium that was being bandied about a few posts ago.
But rubbing a little mercury on a coin isn’t going to poison you, any more than amalgam in your teeth will. Even, I suspect, after the lovely shiny coin turns green with age…
Having said that… using mercury in adequate quantities to simulate metal pours? At Lionel O-27 level of fidelity since the stuff in bottle cars or slag dumps isn’t silvery-colored? That’s like… well, like using unplated DU weights in locomotives because you want contest winners. “Basically” risk out of proportion to reason, indeed. Gallium will ruin most metallic stuff it touches, both irreversibly and with no practical way to get it out or stop it once it starts…
(if you want the slag experience, make an appropriately viscous silicone fluid, dye it with the right combination of UV-fluorescent dyes to show color and dimming when illuminated with different combinations of intensity and wavelength, and provide hidden UV illumination for ‘dumping time’.)
Good advice, Overmod, but in my opinion, such animation is still just another version of Lionel’s “giraffe car”.
I’ve seen plenty of slag-dumping (and a couple smaller spills of steel and iron) in my time in the steel industry…I think sound might also be a requirement for more realism. (Another reason why I don’t use, or need, DCC.)
To be honest, I’d think of it as being more like the Lionel milk-can loader, or those stock cars with the buzzing livestock. It was the mercury pretending to be molten steel that qualifies for full giraffe-car… or maybe the nuclear-waste car with the flickering ‘radioactive’ light… status.
I think you’re right about the sound – would want to have a Rolling Thunder subwoofer, no? And wouldn’t there have to be some concealed smoke generators and fans or whatever down under the roadbed somewhere?
[/quote]
Huh, what did you say? What? Say that again.
He said that the whole idea of ‘realistic’ dumping slag was toy-train-like, and that adding the sounds would be even more toy-train-like so it bolsters his resolve to stay DC-only.
One of the model magazines once published a tip for connecting lighting in model buildings while allowing them to be easily lifted off the layout. A hole was drilled part way through the layout surface and filled with mercury. A wire from the power supply was placed in the mercury and another wire from the building dipped into the mercury when the building was placed on the layout; a kind of open faced mercury switch.
It’s like the old joke, which is heavier, a pound of iron or a pound of feathers? What you want is density (pounds per cubic inch) - iron wins every time
Dumping slag
https://youtu.be/zhJF_hTJ2Rw
Once solidified, slag can be broken up and used in construction
https://www.slagcement.org/resources/news/articleid/2/slag-cement-benefits-and-use-in-concrete.aspx
https://youtu.be/uRfbFVQV4a8
This reminds me of some of the ‘formulas’ in those old-time books of formulas, or the Boy Mechanic books that were parodied in the Iggulden ‘dangerous’ books.
