i have 6 bachmann 4-6-0s some have very loud gear noise, or whine should a dollap of white grease cure this? Also i have hooked uo tenders and turned sound all the way up and can hardly hear chuffs of engine is this a common problem or do i change batteries, or what would like to eventially go to better locos and sound.
Hi Yes they do have poor sound on this unit You can modify the unit by fitting something like Pheonix sound, As for noisey gears yes a LITTLE white grease on plastic gears and moter drive thread. When putting the base plate back on make sure you get the contacts in the right wat round.
