General Prototype Info...
I have been searching for info on a particular railroad bridge in Grand Rapids, Michigan that I have been wanting to scratch build for sometime. I work in construction so I know that the local building department should have record of this particular bridge. However, is there a better resource for obtaining drawings of prototype structures or equipment? Would contacting, in this case, CSX be a better way to go?
Also I am looking for more detailed information about CSX’s mainline between Chicago and Detroit. In particular survey type drawings of their yards. I have looked at topo maps but they provide little detailed information.
Any help is appreciated.
MS
Well if u have no luck at the building department u should do what i have always done. try to take as many pictures of it as u can and build it from that. i made the ohio river bridge which was very huge and i made it from pictures and i was impressed with it.
clay –16 years old
Oh and also if u have any responds to my post just let me know and ill try to help you as much as possible
clay –16 years old
Thanks for your idea. Just to let you know, I contacted the Roads Commision and the guy I contacted has drawings and actually provided oversight for the county on that particular bridge.
These days the railroads would probably be a bit leary about handing out engineering info on a bridge – fear of terrorism. Sounds like a local source is more likely to understand who you are and what you want
Dave Nelson
