General Radius for a 4-8-4
The way my around the roof layout is to be setup, will leave me with a 30’’ radius, or a 20’‘. I’m sure it could make a 30’’ pretty simple, but what is the smallest that it could make, and still be aesthetically pleasing?
The title of your thread suggests you meant to include the stipulation that the curves would be negotiated by a 4-8-4, and if 20" curves would be okay. The answer is…probably. However, there is a real possibility that your particular loco may not like them at all. For example, in a recent thread, I gave the opinion, based on BLI’s Niagara literature, that 22" is the min, but someone else said their N&W J did fine on 18 curves. I’ll bet the J had 80" drivers, while the S1b only had 79"ers. So, since the BLI J was very likely the same platform under the boiler, I felt my advice was reasonable.
FWIW, all locos will look much better on the largest curves you can shoehorn into your space. Also, and I have been disagreed with on this point, your steamers won’t look much different on a 22" curve vice a 28" curve. Once you add a full 10", your eye will really appreciate the difference. And, if your tracklaying is good, they will always run much better on the larger.
Actually, the J had 70" drivers. Since you asked whether “a” 4-8-4 would work on 20" or 30", AND if it would look good doing it, my advice would be to definitely go with the 30" radius. Any 8 drivered loco will look much better, and so will the prototypical 85 foot passenger cars. You may one day find yourself owning a loco that doesn’t like 20" curves; it’s not really very hard to do since 20" is really pretty tight. I have two brass 8 drivered locos and neither of them will come close to running on less than 28" without doing some special stuff.
FWIW anything under 30" would look ugly. But that is my not so humble opinion. Plenty of people will disagree.
Have a look in the November MR for some photos that illustrate that bigger is always better when we are talking about curve radius. I can’t say off hand which page because the mag is at home and I am not. You’ll find it I am sure. Towards the back as I recall. Actually the photos are passenger cars, but same deal.
Many manufacturers claim that their big engines will go around an incredibly small radius. Well they will, but they look terrible in my view because they over hang so grossly and the gap between loco and tender would be a gross safety hazard.[2c]
But then it’s your railroad empire. Do what you have to in the space that you must work with.[:P]
EDIT NEXT DAY. The article starts on page 54. Photos on Page 55.
If you have to squeeze down a bit in a hidden area, you can go closer to the minimum, but for visible areas stick with the 30" radius. But test - always test. If you push to minimums you may end up with a piece of equipment that won’t run because its minimum radius is 1" larger than whar you used.
I have 32" radius curves and my reading T-1 4-8-4 looks darn good. It also handles any 80 and 85 foot passenger cars. But then, the T-1 seems to negotiate #4 turnouts in my yard too (mainline is #6), and the freight-only yard lead is somewhere around 24-26" radius and most of the 80 and 85 foot cars can handle that as well, even with diaphragms. MOST, not all. Some can even couple on the curve - and we do NOT run truck mounted couplers in anything. Everything works on 30-32", most works on 24-26" - this is why you need to test and see what your equipment can handle reliably.
I’d say that if you have room for 30" radius, go for it. Any 4-8-4 will look much better with a wider radius, and most models, either plastic or brass should negotiate it without any problems. It will also look much better if you go for bigger steam, period, such as a 2-10-2, 2-10-4 or most articulateds. And generally speaking, a wider radius–even on a slight grade–means you can haul more cars behind that 4-8-4 of yours.
Just out of curiosity, which model 4-8-4 were you thinking of?
Well, I really enjoy the GS4, Daylight…of course, but I like the black scheme of the Southern Pacic 4-8-4 too.
Thanks for everyones input.
–Austin
The GS-4 is a beautiul machine!
I don’t think PRR ever ran them, but I’m tempted to buy one and change the decals on it to PRR anyway!
Hey it’s my railroad!
For me, the november MR was about the most depressing thing ever. It basically said that unless you have 30" curves, you shouldn’t bother running passenger cars, long locos or basically anything interesting. And I was looking forward to the Trix 32-axle Schnabel*…
  • The manufacturer states it can go through a 15" curve, which is pretty amazing for a car that’s about 28" long.
I probably COULD make a layout with 30" mainline curves, but I wouldn’t have room for anything more complex than an oval. Ergo, I am feeling very :frowning: about it.
Some fun with mensuration tables…
if you run your 28" long Schnabel around a circle of track with a radius of 15 inches, the angle swept out from the front of the car to the back fo the car is 138°. The center of the Schnabel car will be approximately 10 inches from the center of the track. hence, you would have to have a clear area almost 10 inches on the inside of such a curve in order to run it.
man, wouldn’t that be fun to watch!!!
:slight_smile:
Dean
My BLI 4-8-2 Mountain will not negotiate lees than 24" radius, but I totally agree that 30" radius looks much better. My yard ladder is #5s and it does OK on that. That TO radius on the diverging route works out to roughly 22.5" radius. I would say that is as tight as I could go unless I were to equip it wit blind (no flanges) drivers on the center 2 axles. I have a Pacific 4-6-2 with the center driver blind, but I’ve never seen a 4-axle loco with the center drivers blind. I would suggest setting up a test track with flex track and see what your minimum radius the 4-8-4 will negotiate. Tweet
I’m lucky enough to have enough space to do a 30" minimum layout, but still agree with you about the tone of the thing. It really did come across sort of condescending.
Even with a relatively large space for my layout, I had to go with 28" min mainline radius (for the inner track on a dual mainline) and down to 24-25" in hidden areas to get anything even approaching the mainline length I wanted… And a couple of those hidden areas will be so ONLY because they’re smaller radius. My perception is that 30" radius curves throughout is unrealistic for probably the majority of layouts - particularly if (as you say) you want more than a loop. Certainly I’d say even the feartured layouts in the magazine itself have <30" mainline a clear majority of the time. So treating it as sort of a “bare minimum” simply excludes a huge chunk of the hobby…
Not half as much fun as putting one on the rails with its eight individually swinging bogies without the aid of a rerailer. Heck, after a few drinks, you could make it a party game!
Sorry, I meant to post an image for everyone who’s never seen it: http://www.trix.de/produkte/frontend/image.php?bezeichnung=Tragschnabelwagen&nr=24020&picname=24020.jpg
FACT: MANUFATURERS today design their mechanism’s to appeal to the segment of the market they are targeting.
Most expensive BRASS 4-8-4’s would just barely squeak through a #6 turnout. (My $1000 4-8-8-2 would derail).
TODAY’s 4-8-4 mechanisms are designed for 22" radii and #6 turnouts, by adopting smaller-than-prototype drivers and more lateral play (slop) in their design. They are heading for where the market is. 36" radius used to be the standard. Today it is 22".
AESTHETICALLY: A 4-8-4 looks weird on 22" radii.
NMRA says something like 3X -5X the length in inches for " of radius. That translates to 36"r minimum for a 12" engine or car. My personal tests for aesthetic’s: are for an 80’ - 85’ passenger cars to not look ‘toylike’ on a curve takes 46"-48"r.- so I put 46" 90o curves onto 4’ square ply sections (cut into semi-triangles), to make 48" corners. The rest was pure fill-in.
YOUR (PERSONAL) AETHETICS come into play here, as well as the reasons for having them. Differet Tastes. Different Strokes et al. In short, different Thresholds on what you find tolerable. The layout will reflect your Personalty. That is as it should be. YOU will be the one running it.
However; For me, the opportunity to use 30" curves should not be wasted.
Austin–
The Bachmann Daylight locos (both ‘Daylight’ and ‘War Baby’) will comfortably take a 22" radius, because of compromises in their driving wheel diameter and spacing. However, they’re not very good pullers, unless you’re willing to spend the money to put the Bowser conversion kits under them, so I assume you’re thinking of waiting for the future release of the one from PSC (or BLI, I’m not sure), which will probably need a 24" minimum. I have 34" minimum radius on my layout, and two Balboa brass SP GS locos, which look good on the curves and would probably take as little as a 28" minimum radius if I were forced to compromise. However, since you say that you can afford it, I think you should hold out for a 30" minimum. As I said in my last post, even larger wheel-base steam should have no trouble negotiating a 30" minimum radius. Who knows, if you like SP steam, you might start thinking of a Cab-forward, and you’ll REALLY want a 30" minimum for that monster, LOL!
This is a bit off-topic, but it’s peripherally radius-related. What does a “#4 turnout” mean? I assume it’s some kind of standard notation, but what’s the turn radius of the diverging track? Inquiring minds want to know.
I’m fortunate, perhaps, in that I’ve grown up watching Finnish show layouts and leafing through catalogs of every German manufacturer out there. This means I’ve grown accustomed to seeing passenger cars on a 18" to 24" curve and do not consider it aberrant (provided they have decent close couplings and mounts so that the distance between cars is kept to a minimum).
It means that the diverging route moves off-axis from the through route at the rate of 1/4 the distance travelled from the point rail tips to the frog, and beyond. This is because American turnouts have a straight diverging route after the points, so the frog angle matches that rate of diversion and beyond. The rate of curvature, in essence, is about 18", I think…not positive…, for a #4 turnout, and about 26-28" radius for a #6.
I will stand to be corrected, but that should be quite close.
Try this little card:
EDIT: Not so easy to read. Sorry
Hitsua:
I believe that you need a Lt. Radius, rather than a general radius, or you could use a rule of thumb.
Sorry ( couldn’t resist. )
-Ed
You’re right, I can almost read the text on that one.
