My wife says ‘but what do I know’ quite a bit also but it’s not needed; I can see she knows a lot! Happy wife happy life!
Sheldon,
My comments on brass were generic. In the case of F units, I do agree that nothing brass compares to what you can find for running quality and detail to several of the plastic choices.
Mike, I understood your responses to the various comments, and agree completely.
It just seemed strange that the OP asked about a specific prototype, a train pulled by F units, and once again we hear the same comments about Genesis light bulbs, brass is better, etc.
I don’t know if Genesis F unit bulbs burn out fast on DCC - but it is pretty easy to change on an F unit. On my system, maximum track voltage of 13.8 pulse modulated DC, I’ve never had problems with any factory headlight setup - but I don’t have decoders in any locos either.
Sheldon
Just had all of the lights to go out on a Genesis SD70M but the unit is from the first run and DC think that is good for a loco that old.
Russell, you will have to excuse my lack of knowledge, but how old is this loco? I have no idea when Athearn first came out with the Genesis SD70M. Being a modeler of the 50’s and not really being a rail fan of present day railroading, I have to admit that I could not even visually identify an SD70M, its just another big modern diesel to me…
But if you got reasonable service out of the light bulbs with a DC model, then it seems it may be mainly a DCC thing where so many complain abouthe bulbs.
Sheldon
I think i got this SD70M around 2001 and i have several more with lights and some with half the lights.
Sheldon,
On the Genesis F units, many have fairly decent reproductions of the dual filament lamp assemblies used. So each headlight has two tiny bulbs that require a fairly exact size replacement be used to preserve the detail. Depending on the road, there may be two lamp assemblies on a F unit. So 4 bulbs to potentially fry, even assuming nothing like ditch lights, overhead beacons, etc are also involved.
Athearn glues the bulbs in. I’ve found no bulb that really matches the size unless you go directly to Athearn for them. They are 1.5 volt and driven by a small board that supplies the proper step down from 12 volts on DC when unmodified. That does OK, but people still report losing lamps on DC. What happens is that going to DCC ups the supply voltage to the typical 14 v or more. But people tend to calculate as if they’re stepping down a 12 v circuit, because that works most of the time with such conversions. However, the bulbs Athearn uses tend to go out rapidly when under the same circumstances others seem to weather this small difference when converted.
Not wanting to have to visit Athearn every time a bulb is lost had me simply convert mine initially. But the DCC command station adjustment solved the problem with much less labor and cost than that.
I’ll try that since I been mulling over the idea of getting a Topeka cab GP7.Still that’s no excuse for crappy bulbs in what is suppose to be a top of the line locomotive.
The sad part is Athearn is well aware of the problem.
Mike, I’m not disputing the problem, I just have not experienced it. All my Genesis F units are factory DC, many were bare drives for Highliner shells.
None of my Genesis F units have burnt out, and when I installed the lamps in the ones I built from Highliner kits, I did not find it necessary to glue in the lamps.
And, admittedly, in my world - what is a ditch light? I model an era when they were just thinking about turning headlights on during the day…some of my stuff has Mars lights, but I don’t go out of my way to add them to anything.
Sheldon
As for the incadesent bulbs, they can be replaced with LED’s weather DC or DCC. That task is fairly simple and if one does not have the skill required I am sure some one out there can be found to do it a fair price.
I have diesels from all the mentioned manufacturers (including a Genesis F3/7 with MRC sound) and they all have good and bad points. I have had most of the Gensis bulbs burn out and replace them with SMD’s glued to a short pc of 1.5 mm fiber optic fiber.
I only have one brass diesel (SD9 by Hallmark) and it is in a display case, but the brass steamers I have, a United 2-8-2 and Tenshodo 4-6-4 have a couple of advantages over their plastic counterparts (imo)and that is weight and the fact that I can pick them up without worrying about breaking some small detail off.
-Bob
Sheldon,
I think the complaint about Athearn headlights is more about them gluing them in rather than the bulbs burning out. At some point bulbs are going to burn out. When you make it difficult to remove and replace a headlight without damaging the shell, that’s where Athearn needs to change their assembly practices.
I usually replace any incandescent headlight with a 3mm LED and I NEVER glue an LED in. It’s either press fit in a #32 (0.116" OD) hole, or the bulb end is secured in place with a short piece of black heat shrink. If and when I should ever need to replace the LED headlight, all I need to do is unsolder the wires and remove the LED.
I suspect that is because you run in DC. On my DCC layout, my Genesis F units had their incandescent bulbs burn out within hours out of the box.
Well I have owned a half dozen Athearn Genesis F units. Apparently some folks on here have not run theirs much. The ones I owned had issues running at different speeds and uncoupling due to speed variations in plain DC mode. Also the wheel plating was crap and started coming off within 20 hours or less. The light bulbs dont last in plain dc mode either.
There are good reasons I prefer brass. I always had very good experiences with the running performance of Overland Models tower gear drive diesels. Some brass f units have been gorgeous and some not.
If money is a concern I think p2k F units are the best of the plastic because they have run the best for me.
Intermountain F units tend to sit nose high and that bothers me. I was not able to fix mine to sit level front to rear. They run ok.
Some Challenger Imports f units have coupling issues where things do not fit or mu correctly. My problems were with WP units which I resold and they held their value.
Never had any coupler/uncoupling issues…but the first thing I do with EVERY piece of equipment is replace the plastic semi scale couplers with regular head metal Kadee couplers. All my F units are three and four unit powered sets, they run fine together.
I have one set of Proto F units, and they run fine. But I use some of my ATLANTIC CENTRAL F’s for passenger service and the Proto’s are slow, I don’t like that they changed the gearing.
But again, I don’t run my DC engines on the MTH promoted 16 volts, and none of them have sound or decoders, I run them near the “original” NMRA Standard/RP 12 volts…
My Intermountain units look fine, I think I had one that was nose high, but was able to fix it. I have a bunch of their FP7’s, another reason I prefer Intermountain - undecorated kits…which are now hard to find in Genesis…for
It sounds like you have been lucky, but the OP is probably interested in trends and issues affecting enough people that he may want to include that in his decision making. An “outlyer” piece of data is just that, an outlyer. In other words, if one or two people didn’t have bulbs burn out on any of their Genesis loco’s but 50 people did, who are you going to believe? I’d think the large numbers speak the loudest.
I have read reports from many many people complaining about Athearns light issues for the past 10+ years so I’d say thats “significant” enough to factor in. To me, it’s not a deal breaker and I’m not going to avoid buying types of diesels that are important to me over a light bulb, but I understand there are a few that do.
I understand and agree, I full well admit that my experiance may well be a direct result of my unconventional control system, that actually conforms with original NMRA standards…silly me.
Sheldon
I recently forked over $25.00 to have LEDs installed in my Genesis GP9.To my mind that’s fixing a problem Athearn should have fixed by now. The other manufacturers uses LEDs in their DCC ready or DCC/Sound equipped locomotives and that includes Bachmann.
But,like I mention I’m thinking about getting a Topeka Cab GP7.
Sheldon–
For the record, I abandoned and sold the MTH DCS system (that I once was a fan of) after my sons got kinda bored with steam, some years ago. The MRC Tech 6 Sound Controller 2.0 actually runs some engines slightly faster in DCC Mode than they run in plain DC mode. I don’t know why that is true, but with some of my engines it seems to be, I guess depending upon the decoder in them.
I’m pretty sure the MRC Tech 6 is closer to 12-13 volts, max, in plain DC and not the 16 volts of MTH.
So my Athearn Santa Fe F’s which were supposed to run together would not. They ran at speeds so different from one another that they would uncouple (and yes, I had Kadee couplers on them, if I recall). The A and B of an AB set would literally not run together in plain DC. Nor would the A run with other A’s, but at different speeds.
These were prior to 2011 Genesis units, if I recall. I have only attempted some Genesis GP7’s, 15-1’s, and rtr SD45T-2’s since 2011.
The SD45T-2’s were the nicest models of all Athearn diesels I owned in the last 15 years. Best QA/QC and they ran well. Oh, I had one Reading Genesis GP-7 that was awesome. Just opted to do something other than Reading and had trouble finding a decent RS-3 in green and yellow…never found one and gave up.
Others may see it differently.
John
After years of replacing and hating the burned out Genesis incandescent bulbs, I took the advice of some smart people on this forum and installed SMD (surface mount device) LEDs in my Athearn Genesis F7A locos.
Life has been good ever since. [Y]
