I recently purchased this engine in Alaska and I want to convert it to DCC. The main board is labeled “GENESIS DCC LAMP BD”. Coming off the main board is a harness with a 9 pin connector, plugged into this is a small board with what appears to be 3 diodes. On the other end of the main board there is also an 8 pin connector with nothing plugged into it. I tested the engine on DC and everything works well.
Which connector do I use for the DDC chip and does this “LAMP BD” reduce the DDC lamp voltage to 1.5V for the existing lamps? Is this main board both DC & DCC (it did not respond to address 03)? There was no instruction sheet with the engine, just a parts blow up. Any help would be greatly appreciated.
You can use either a decoder with a 9-pin JST connector, or one with an 8-pin NMRA “medium” connector. In either case, you need to remove that small jumper board from the JST connector.
And yes, the “DCC LAMP BD” contains the necessary circuitry/components for the existing lamps. If you plug a decoder into either of those sockets, nothing additional is needed for the lighting.
I believe with the JST 9 pin you can configure for ditch light control as well.
Richard
Thank you for the info. This is the first time I have used this forum and I am amazed at both the speed and number of replies in a short time. Your responce clears things up for me. Thanks again, Doug.
Make sure you remove the small board in the 9 pin. Otherwise you can fry something.
Check that…you WILL fry something.
David B
