It has been a while since I have been in the hobby of model railroading. I have retained my HO Scale locomotives and rolling stock. My first model railroad was a 4X4 set and at that time I had only two locomotives and few rolling stock. I am up to about 7 locomotives and about 20 pieces of rolling stock. I have an area in my basement that is 12 X 20 feet. My main issue is trying to figure out how I can lay track so that I can run a locomotive with say (4) Walthers 85’ Amfleet/Horizen coaches. I have been trying to stay away from using 18" radius track. Is 22" radius acceptable for this? Aother issue is figuring how to determine % of grade. In my notes I have that 2% is an acceptable grade. All of my previous layouts were boring because there was no grade.
When it comes to my passenger trains I wanted to model push and pull service and build along the walls. I would plan on finishing it in sections but would like to at least start with working on the grades and laying track. I am impressed with the layout in Model Railroader March 2005 issue ppg. 49 -55.
I have a whole collection of HO scale vehicles from Atlas, Boley, Herpa, ConCor, Road Champs, Monogram and others that I would like to incorporate.
If you have have any answers to my questions please let me know.
Walthers cars will go around 22" curves with no problem.
Some will say that it doesn’t look correct, you should go with a larger radius.
If you have the space, go for it. If not, don’t worry about it.
I have 22" curves on my layout on the mainline & I’ve have no problems with Walthers 85’ cars with these curves.
2% grades will depend on the locomotive power you’re using.
I have 3.5% on my 9x12 layout & my Proto 2000 PA has no problem pulling 6 of these cars up this grade.
If you have that much area available skip the 22" consider going as large
as possible, 30" with easments.
As for grades 2% is a rise of 2" over a length of 100", so the easy way would
be to screw a block of wood (2X4) to an 8’ stud, 96"
also try a 1" piece on a yardstick 3% grade.
Woodland Scenics makes a foam roadbed product with grades built in that is flexible so you can use it on curved sections also.
To be honest, I didn’t measure the grades until after I built them which is why i have 4 different grades on my mainline.
I put a riser at a height tall enough to get a train through a tunnel & went down from there.
I’m still working on my trackwork so I haven’t started work on scenery.
If you want, I can show you pictures of my benchwork.
May take me a few days to get them but I can email them to you if you like.
