getting started
I’m new to this hobby and I was wondering if you can give me some tips on getting started.
I am reposting this reply from the I NEED HELP posting…
First, Kalmbach publishes a "getting started in garden railroading " book that is a good starting point, its mostly a collection of articles from past GR issues, but I would also get “large scale model railroading” by Robert Schliecher. Its more detailed and has a lot of good tips.
Second, START SIMPLE keep it to continuous loop(s) (I didnt say small) and a couple of passing sidings for now. I always feel its more important to get the layout running than to be building forever and your trains are collecting dust. You have more incentive to continue when you actually see them running around the yard…
Are there any natural features that could accent the layout? streams? gullies? hills? rocks? Try to work them into the layout in the same manner they would on a real RR. Sketch it out first, then use caulk powder to layout where the track will go then step back to where you will look at it the most and decide if thats where the track looks best. What looks good on paper may be very different in reality.
For indoor layouts switches and sidings are no problem, in the garden though its a headache to wire switches back to a common point, especially if there over 100 feet away so I always feel that in the garden track should be layed for running, not switching. It would be better to have multiple loops with just passing sidings so you can run more than one train, with DCC you could run more than one train on the same track. Any yards, stations, engine houses, etc. should be at the most easily accessed part of the layout, usually next to the operating deck.
Third, I use brass track as its the easiest to get. Whether you decide to use flex track, sectional, or whatever brand, I would use LGB switches only. This is a personal preference but I have had too many compatability problems with Aristo-USA switches and will not use them anymore. LGB locos stall on them and my Bachmann Annie
Also read Cacole’s replies to the I NEED HELP posting on this forum. His advice is also excellent.
Also, check this web site (gardenrailways.com) in the “for beginners” section. You can also call 800-533-6644 and we’ll send you a free beginner’s booklet.
