I was running my trains the other day and all of a sudden my Genesis F3 started to come alive without any input from me. It started ringing the bell and then went through a whole series of random sounds and I hadn’t run this engine in a couple of days. I know I dispached it when finished as I always do. I entered the address and took control (it didn’t move on its own, just made many sounds!) and exited again. Any ideas as to what might have happened?
Did you try setting CV29 to 34? The problem you saw might be a dc mode issue. During system start or if there is a sporatic short in the layout it can cause decoders with DC mode on to take off.
If that doesn’t fix the problem try a reset of the decoder.
I have two Genesis F3,s with MRC sounddecoders that behave like that after approx 1 hour of sitting idle on a powered track. The funny thing is that one of the random sounds is talk in in a funny language maybe Chinese ?[:O]
I will replace the MRC decoders with Tsunamis byt have not gotten around to that yet.
That is what I was going to say. MRC decoders? IMHO the MRC decoders are subject to “electrical noise” and don’t handle it well and the cause of most of their problems. I have had a couple that I thought for sure were dead no matter what I tried. After months I tried them again and they started working. This was after I got another one working and decided to try those once again. Weird.
Is MRC the sound system used by Athearn in the Genesis line? I thought it would have been a better quality decoder for the money they get. Mine is about 4 years old but never ran it much until a few months ago when I switched to DCC. It is a great running and sounding loco though.
They were, but AThearn got enough complaints about the poor quality and frequent failures that a couple of years ago they switched to using Tsunamis from Soundtraxx.
Read CV8 if you can, 141 is SOundtraxx, 143 is MRC.
Or take off the shell and look at the board. MRCs tend to look like some amateur soldered it together in their basement, Tsunamis look professional.
Or, when did you buy it? If it was before 2008 it is definitely MRC. Around 2008 it could eb either, if it is a new run from the past year or so it’s definitely a Tsunami.
I remember reading how the MRC decoders were very shoddily made and the factory that made them was described in very poor conditions. I’m so glad I opted to buy all my Genesis F units without sound. All but one was pre-Tsnumai. The last one I bought money was getting tight so I just got the non-sound F7 (phase II D&RGW #5764).
I pullled out the mfg literature from this engine to see what CV would lower the volume on the sound system and found a statement in there about Athearn using MRC decoders in these engines. I never thought to look at the booklet? It also showed a volume pot on the pcb that adjusts the overall volume, which I did. It also mentioned that because the decoder was MRC there was no CV read back capabilitiy. I haven’t had any problems out of this engine since I first posted this thread. Thanks again for all the help.
BTW while I had the body off it noticed it had the push-on connectors so I removed them and soldered all the connections.
