I’ve made a couple High Rise Buildings and looking for a Mirrored or Smoked Window Finish and if possible to light it up from the inside so I get the desired look of a real High Rise. I’ve tried Window Tint (to fragile) (have clear plastic-spray painted Black-Iffy?) and have made calls for Smoked Acryllic (tooo Expensive) if anyone has any other ideas that would be Great!
On a recent thread one of the forum members recommended using cellophane wrap for windows in large buildings. Try your local Dollar Store. You might be able to find it with a silver tint that would still let the light through.
Dave
Michael’s has rolls of tinted cellophane. I’m not sure if they have black (smokey.) I can check this weekend. There’s one up the street from me.
Steve S
Thx Guys for the Quick and Reply; Will check out the Dollar store and Michels this afternoon.
To me real glass gives the best look. Microscope slide covers come in all sizes, as large as 7" x 5". Low quality, unsterilized ones are relatively inexpensive. If you know a Veterinarian or someone that works in a lab, you may be able to score a few.
Try an automotive place that does window tinting. This stuff comes in rolls, and they no doubt have scraps they’ll probably give you.
Thanks for the quick help everyone; the Cellaphane & window tinting were to thin and couldn’t find anything at the Dollar Store…Never Ever Would have Thought of the Slide Covers for Microscopes…I’ll put a couple pics up to show you what I did with tinting which didn’t work so well.
Something I used in the past with success is Saran Wrap Cling Wrap. Lay down a thin bead of glue at the top inside of thructure. Stick the wrap to it, let it dry, then carefully roll it down the inner wall.
While it might seem unrelated, I have been using old Xray film to give a smoky effect for industrial windows. I got some from some old film I had that no doctor would recognise but when I needed more, I went and asked at a clinic if they had any spoils/out of focus pix they had. Consequently I had been given a bluey sheet, remarkably consistent, that could be lit from behind and framed etc with plywood and done fairly cheaply,
Hope this helps,
Regards from Australia
Trevor
I just stopped by Michael’s and they didn’t have any smokey gray cellophane.
Steve S
So which “office” glass method did you go with - tinting sheets or something else?
Also, is the office building wall supposed to be stucco?
The windows are a clear sheet of plastic (approx .20 thickness) and painted Styrene Black (used .010) and the building I did Stucco with Glue & Sand.
I have used film negative. Bought a roll and told them "just process it, no pix, just the blank negative. You do remember film cameras don’t you? Oh well, just what I’ve used.
Wait a minute, I just realized - wasn’t the Original Poster with the question on mirror glass “Old Dawg” - are you the original poster, Magnum019? I’m not sure which poster is which.
I’m the Same Poster; I couldn’t find my Old ID and just Created a New One; It’s now being corrected and the New one Deleted, Sorry for that confusion.
