Glue Sprayer
Hi,
I am looking for the most efective glue mist sprayer available. I have found a few that work OK, but I still not satisfied. I found out early on that trying to spray a pva white glue / water mixture was a losing proposition with a room temperature liquid. I surmised that heating my glue/water mixture in a microwave to at least 160 deg F will reduce the viscosity enough to work quite well for a while until it cools off and begins clogging. Works very well. So my question is what fine mist sprayer are you using with pure water that is the best you have found to produce a very fine yet controlled mist without an excessive amount of air turbulence? Thanks.
John
