will Spot gluing my eztrack be strong enough to keep in place. I dont want it to move around once i start building the tunnels. And will it be easy to remove the track if i have to move it or replace it for some reason? I dont think nails will work since im using cheap foam[:$]
Place it where you like, test and retest it, then secure w/ DAP Alex Plus caulk. Isn’t the roadbed hollow? It will still work may need larger amounts “ploped” here and there. Could also run a small bead along the sides. Kinda like caulking down a hollow ribbed aluminum threshold. Weight it down and since you are using more than a thin skimmed layer.
This stuff is available at most home improvement stores.
It holds tight and can be pried up easily.
Ditto to Bob and Dave’s suggestion above. Great stuff…and it’s only $2/tube.
