GN SD9 Detail
As a modeler of GN trains I was looking through the excellent books “GN color pictorial vol.1-4” for details and their position, e.g. horn, antenna … On the SD9 long hood there is a detail, covering partly the third window of the ventilation grid. I try to attach the photo. For long time I was looking for the meaning and name of this detail, with no result. Can anybody help? Can one purchase this detail, e.g. from details west?? Otherwise I would make it from a piece of styrene.GN SD9 #586
I know little of the GN’s peculiarities, but those look like vents or exhausts of some type.
I looked it up and it’s just what I expected, an exhaust for an engine heater. There’s a reference to it HERE…just scroll down a bit to read it.
EDIT: By the way, [#welcome] to the Model Railroader Forums. Your first few posts are under moderation, so be patient, as you’ll soon be allowed to reply.
BTW if we’re talking about the fire-extinguisher shaped tube over one of upper vents on the long end, note that it’s over the 2nd vent not the 3rd…if you’re counting from the front. [;)]
Earlier, I was searching different sites to see if I could find a better view of that exhaust stack.
It seems most of the GN’s SD9s had what appears to be an outer hood over the vents you usually see.
Mike.
