After you introduce a plan with some grades which take off from a turnout, it frequently seems possible to cut a “tongue” out of a plywood sheet tabletop and elevate it with risers attached to crossmembers from the table framing. What is the strategy to determine the location of these cuts for the elevated trackboards? Does one merely lay out the grade track on the deck, mark it, cut, and push it up? I have how-to books which mention the so-called cookie-cutter approach, but none which actually show in process as it is executed.
also as you cut the track boards in the vicinity of 3 1/2 inches wide, how do you provide a basis on which to mount a tunnel? Do their locations have to be precisely known as the track boards are installed and add those positions a 90° extension on each side of the track board is cut out of the trackboard material?
any recommendations for a good book?
