GP 15 engine
Hi all,
I am trying to find any info available on the GP 15 engine. I get an error message trying to find this engine in trains/trainset when I load MSTS. Any help would be appreciated. my e-mail is yllek1@charter.net. Thanks.
Earl
Which GP15 do you mean, the EMD versions built in the 1980’s mostly for Conrail and MP, or the ersatz version built by MPI (it’s almost identical to an MP1500D) and only marketed by EMD?
A GP-15 is not a default engine in MSTS that I am aware of. Go to Train-sim.com and you can download many different paint schems for use with MSTS.
Paul,
As I mentioned in my thread, I get an error message after MSTS has loaded looking for the GP 15.eng and the AMD 103.eng in trains/trainset. I can’t find any program on my computer that uses these two engines. I thought, if I can download them from somewhere, I could then stick them in my trainset and that would satisfy the error. I don’t have any further info. Thanks for your help.
Earl
By an chance have you downloaded an add on scenario that uses non-default files? If so it is looking for these and you need to download them also. The directions for the scenario should tell you what non-default files you need and it is probably those two engines.
